Question about Hunter Kenroy 50151cop Kenroy Montpelier Copper and Slate Floor Fountain
Model D177485 Pump and light will not turn on
There are two black/gold wires on an 04 Mitsubishi Outlander connected to fuel pump, which one is the ground for the pump?
Turn the key on while probing the wires, the hot lead will light while the engine is being cranked or will light for 1 second when the key is first turned to run. You did not include any vehicle make, model or year kinda handicaps my ability to answer. answer.
Oct 06, 2016 | Cars & Trucks
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
Hard time to start but when it turns on I hear the fuel pump relay clicking a lot and the idol start going up and down until the car turns off and by the way I got the track light on and the check engine...
Year make and model ?
Have you swapped the fuel pump relay with another ?
Its normal for the traction control light to come on if the check engine light is also on.
Have you checked the engine computer for trouble codes ?
Mar 27, 2015 | Cars & Trucks
Control light ON model # GHW9250MWO
turn off the mains
open the door
drain fully!!! and clean and clear all the drains and pump
and any traps in the pump waist path
here is page 18 troubleshooting
it says its perhaps he pump
anyway the user manual is the place too start
http://laundry.manualsonline.com/manuals/mfg/whirlpool/washer_1_2_3_4_5_6_7_8_9_10_11_12_13_14_15_16_17_18_19_20_21_22_23_24_25_26_27.html?p=18
Mar 04, 2015 | Whirlpool duet Washing Machines
I have a Miele dishwasher model G2120SCU. When turned on, all three yellow lights light up and the unit will not begin wash cycle but makes a noise (possibly the drain pump??). Any idea what the three...
Yes, It means call the technician 800-999-1360
Three blinking lights can be anything either- no drainage, no water, no circulation pump, no salt, etc. based on the model. Each control board code is different on each model.
The technician will provide free step by step instructions to clear the fault and advise you how to get the problem fixed.
Dec 27, 2014 | Miele Dishwashers
My abs light came on and the hydraulic pump stays on even though the car is turned off
Replace the ABS pump relay first. You have not provided any specific info on make model of vehicle. If you need more help please post this info.
Mar 16, 2012 | Cars & Trucks
My 99 s10 has no check engine light even when just turning the key, won't start and the fuel pump wont turn on. Changed ECM, Body control module, and ignition switch. I have checked all Fuses and...
IF FUEL PUMP RELAY IS NOT WORKING THE COMPUTER IS NOT READDING IT THEIR IS NO BYPASSING THE COMPUTER(ie) DOT CODE on that model vehical THE MASS AIR SENSOR REGULATES 90% OF HOW THE IGNITION TIMING RUNS I USED TO GET AWAY WITH IT ON OLDER MODELS NOT ANY MORE!?
Aug 30, 2011 | Chevrolet S 10 Cars & Trucks
How do i check the fuel pump relay and the fuel pump to see which is the bad part on a 99 Yukon 4x4, 4 door model?
The fuel pump relay should have a schematic on it so you can check it with an ohm meter for a short. If it checks ok and when you turn the key on, you do not hear the pump then replace the pump
Apr 28, 2010 | 1999 GMC Yukon
Continuous draining - unable to reset - all lights on
Cut power for minutes, and see if this can stop and reset the machine.
If the machine does not reset, then you need to test the pump and valve solenoid, to ensure it is not stuck on drain position, by energizing the solenoid.
If the pump solenoid is fine, and pump opens and close, then the problem is usually the control panel, rarely can also be a contact on wiring harness to the pump.
Eneter model number here to find parts and diagrams for your appliance.
Here also parts and repair help.
Feb 26, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Hunter Kenroy 50151cop Kenroy Montpelier Copper and Slate Floor Fountain Logo
60 people viewed this question
Top Hunter Kenroy Garden Experts
Dennis Key
Dennis Key
john h
Are you a Hunter Kenroy Garden Expert? Answer questions, earn points and help others
