Question about Brother MFC 420CN All-In-One InkJet Printer
Printer Head needs removal to clean dried ink
Read out said Cyan empty, replace. before able to replace message says no ink cartridge. place ink cartridge and close cover. suspect ink is dried on sensors and needs cleaning. How to remove to clean?
  • 1 more comment
  • Anonymous May 17, 2009
    This response is a little helpful -- I can see the flag in the bump and it seems stuck there in spite of being nearly full.  Very frustrating -- I's love to print in just black right now instead of deal with this.
  • Anonymous Mar 18, 2014
    door
    we had a power outage and after the power came back on my printer says "unsupported ink cart. U059 Blk."
    I've removed the cartridge and cleaned the printer head, and still nothing.
  • Brother Master
  • 1,113 Answers
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Posted on Jan 26, 2009
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
Says the cyan ink cartraige is empy but it is new, replaced it with another new one and still says its empty
remove all cartridges and close the lid. Wait for "ink cartridges missing..." error to appear then install all cartridges and close the lid. If the error persists, remove all cartridges then clean the cyan chip and corresponding contacts in the printer with damp cotton bud. Dry well (with dry c/bud) then fit cartridges back in. If still no good, contact HP.
hope this helps
LC1000
www.inkbank.com.au
Dec 01, 2010 | HP Photosmart C6180 All-In-One InkJet...
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I haxe recently purchased a brand new canon mp530 that is still under warranty.I don't allways have the problem but often enough for it to be one.Adout 90% of the times I try to print I get an error...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
Soruce: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
After installing new cyan cartridge, display reads No Cartridge
look at the ink cartridge and and first see if the ink covers the top of the cartridge. there is a little part of the ink cartridge the best way to explain it, is there is a tab,. that tab goes into a sensor. if the tab has ink on it, then you mostly like have a problem with the sensor itself. but if there is no ink, the printer is correct. i have had several people bring printers with those type of problems, and when they bring the cartridge i look at it, and they are practically empty.
thanks
Jun 26, 2009 | Brother MFC-5440CN All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Replaced ink
unplug from power outlet. wait 5 min. take ALL carts out. leave scanner top open. replug to power. wait til machine demands carts. insert carts. close cover. answer display question.
Do make a firmware update. download small tool from brother homepage of your country!
Mar 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
760 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
