Question about Harman Kardon CDR30 2-Disc CD Recorder
My hk cdr 30 no reading any digital audio inserted disc. otherwise everything
Else works fine
  • 1,267 Answers
CD do not just read any types of files, the disc must contain only files compatible with the unit. Check your manual.
Posted on Jan 25, 2013
3 Suggested Answers
dvdcdlaser
  • 1285 Answers
SOURCE: I have a Harman Kardon CDR 30 that I use to burn
try plugging the HK30 out to R2R in, R2R out to RECV in...RECV (you may need 2 rca "Y" connectors) tape out back HK30 & Cass
the "Y" connector needed is (2) 2 female to 1 male (connect both HK30 & Cass deck)
Posted on May 21, 2010
dvdcdlaser
  • 1285 Answers
do you remember how your connection was before the RR tape deck? if so connect it back that same exact (when every thing was recording / playing) way as before....(you also need to purchase 4 gold tip "y" connector jacks (2 RCA female to 1 RCA male)) ... in / out jacks you just plug the cassette deck will be shared with the RR tape deck...just note you will not be able to record from cassette to RR tape or vice versa...but you will be record from all other sources...
feel free to rate the help
Posted on Jun 20, 2010
My Yamaha CDR D651 appears to dislike new 50x maxell CD-r discs saying not audio. Works fine with 12x discs. What's wrong? Rowan
you probably have regular cd-r disks that cannot be recorded on in this unit. You can only use disks marked "DIGITAL AUDIO" for recording
Sep 16, 2014 | Yamaha CDR-D651 2-Disc CD Recorder
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
I have a Harman Kardon cdr 30 that I use to burn my analog Vinyl and cassettes to cd. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
May 15, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
I have a Harman Kardon CDR 30 that I use to burn my analog Vinyl and cassettes to CD. I have done this successfully for years. I recently got a reel to reel deck and unhooked all the components and moved...
Mar 27, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
Cdr s1000 help
Hi Rick
The unit has stopped reading discs. I suggest taking the lid off and cleaning the laser lens with a cotton bud with a little Windex , then give it a gentle polish to be sure no residue smearing is left. If that does not fix it, check to see what actually happens when you load a disc. Does the transport fully engage and clamp the disc correct into the chucking assembly. Let me know how you got on:)
regards
Graeme
Apr 06, 2008 | Yamaha CDR-S1000 CD Player
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
73 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
