Question about KitchenAid KSSC48QMS Side by Side Refrigerator
Kfis27cxms0 display and dispenser not working
Have a KFIS27cxms0 K/A Fridge. Display half works; can use corner buttons [e.g home, ice] but the central portion of the display is unresponsive to touch. Any troubleshooting options?
i looked up your model number,that display board is over 600.00.i would call the factory number and let them look at it.you can try unplugging it and see if it resets but that machine has some big money parts to have someone take a guess at,most likely they'll have a diagnostics tool that plugs into it and will tell them what's going on with it.good luck.
Nov 23, 2017 | Refrigerators
Not Dispensing water?
I have repaired this problem in two different ways. Unplug the unit. First try removing the dispenser display cover to access the electronics. One at a time clean the terminals of all connectors. Try to see if that has worked. If not, look for a relay that controls that dispenser and replace it. Good Hunting.
Apr 27, 2014 | GE Refrigerators
Rfg238 display panel not working
Sounds like you need a new display board, it lives brhind the panel.
Nov 15, 2013 | Samsung Refrigerators
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Side by Side Refrigerator ice/water dispenser computer problem
You either have a loose wire or you'll need a display board. The only other cheap thing that you can try is to unplug the unit and plug it back in. But if that doesn't work then it's one of two things. Are you sure that you don't have a extended warranty on this unit? Is this a GE unit?
Aug 12, 2009 | Refrigerators
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
The ice maker is making ice but won't dispense any ice or water
Stop, the first thing to know is if you are getting voltage to the rotator srm in the back of the freezer
Mar 14, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
KitchenAid KSSC48QMS Side by Side Refrigerator Logo
24 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
