Question about ASUS Eee 4G Notebook
Blank/Black Screen Asus PC 4G
Hi, my husband was playing around with screen resolutions and restarted computer to apply changes, and now all we have is a blank screen. Windows XP looks like it loads, then goes straight to the black screen, We have plugged in another monitor and nothing appears on this either...
Please help! Cheers, Shona
  • shona_jamie Jan 26, 2009
    I tried this, but it did nothing...Thanks anyway Guru
    Anyone else got any ideas?
  • Anonymous Apr 04, 2009
    hi my computer died so i left it there then charged it the next day the day after that i tried to use it but it didn't work we have tried everything PLEASE HELP
    President:
  • ASUS Master
  • 1,314 Answers
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Posted on Jan 26, 2009
  • Kevin Shafer
    Kevin Shafer Jan 26, 2009
    Well thanks for the bad rating since you didn't put that information in your request.
I change my screen resolution to the highest setting and my screen become blank (black with blue screen in the middle). I cannot change the resolution again because the screen is blank.
Try to restart the computer in safe mode. At start up press F8 key like your are trying to get the computers attention. You should get a start up menu. Chose Safe Mode. Once in safe mode reset the screen resolution to is lowest basic setting and reboot. See if this will help. Do you have a good antivirus program. While in safe mode run a scan also. Hope this helps Fixya up.
Dec 19, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
OUT OF RANGE: this words appear on my monitor, and it does not change. the monitor is black always.
The resolution your pc is set for is not compatible with the monitor.
To fix this, you need to start the pc in VGA mode. (640 x 480 lines) Start the computer and begin tapping the F8 key about once a second till you see a text screen with options displayed.
If you recieve a stuck key error, clear it (read the message) and continue to tap F8.
Choose the option to boot in VGA mode. When pc starts everything will look very big, like you're zoomed in.
Now you can change the screen resolution. Right click on background and choose properties, or display options, (depends on your operating system) find the option for resolution and change it to 800 x 600. (The screen will not change then and ther) Apply or OK the screen then restart the pc normally. Now you should be able to see more of the screen.
Go back to the resolution settings, and adjust it to your likeing and the limit of the monitor. Now it will apply immediatly, - click the save option that pops up with the change to lock in. If screen becomes unreadable, just wait 15 seconds and it will change back.
Dec 02, 2010 | BenQ Computers & Internet
I adjusted resolution on my HP notebook now when I turn on cant see screen. Please help
Hi Jess,
Boot the computer in SAFE MODE by Restarting the computer, and the moment its on keep tapping the F8 key untill you see a screen saying "Windows Advanced option...".
1. Select Safe Mode using the keyboard arrow key and hit enter.
2. This will load all basic drivers to start safe mode operation.
3. Go to Display Properties (WindowsXP) or Display Settings (Windows Vista) by right click on empty blank space on Desktop, then select Properties(Windows XP) or Personalize(Windows Vista).
4. Then change the resolution by sliding the Low to High slider bar. Do not press "OK" or "Apply" at this time.
5. Instead, click on Advanced Settings, and then click OK. Windows in Safe Mode will change the screen resolution according to new settings, and prompt a "Monitor Settings" dialog box prompting that desktop has been reconfigured, with countdown timer. Click on Yes to keep the new settings.
6. Alternatively, simply click on Advanced, go to Adapter tab, then click on List All Mode. Select a mode with screen resolution size and color mode that you prefer, and click on OK. Windows will apply the new resolution size and color quality on Safe Mode too.
Regards
Riztech
Oct 17, 2010 | HP Mini 1000 Netbook
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
My asus eee pc 4g desktop is bigger than the screen size so i cant see in full and have to scroll up and down. any solutions?
In short, no. The resolution on those LCD panels is extremely small and was originally designed for the small proprietary OS that came on them. Eventually Asus started putting XP on some of them, which was designed for 800x600 at the very least. As a result a lot of standard Windows dialog boxes are taller than the screen and make access to the buttons on the bottom difficult. One solution would be to use an OS that's designed for LCD screens with low resolution, like Ubuntu Netbook Remix. The only other solution is to upgrade to a netbook with a higher resolution screen, like most of the 8" netbooks.
Apr 18, 2010 | ASUS Eee 4G Notebook
Icons too big on desktop
Hi there you ca adjust the screen resolution by right click on the desktop mean u close all pages then right click, select properties its at the bottom, a box will appear click click settings and sat bottom left you will see the settings for the screen resolution set to 1024 by 768 and you will be fine
thank you
if this was helpful to you kindly vote for me
hbristol173
Mar 31, 2010 | ASUS Eee 4G Notebook
Asus eee pc resolution vs. screen
Your computer does not support any resolution greater than 1024X600, anything other than that you will have issues.....
Display Screen Size: 10.0" Display Type: WSVGA Max. Resolution: 1024x600
Oct 12, 2009 | ASUS Eee PC 1000HA Netbook
Hi, i can not wach tv program, the pc screen is too small
hi, reduce the resolution and frequency rate of the graphics card.
Jul 04, 2008 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
566 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
