Question about Black & Decker TRO651 Toast-R-Oven Toaster Oven with Convection Cooking
Light does not come on
The light does not come on for toasting or oven setting. Therefore, nothing is working. What is the problem? Is there an easy fix or is it time for a new one. Thanks for your help.
See http://www.fixya.com/support/t153483-no_oven_but_still_toasts. the suggestion for thsi problem helped us withthe problem that you describe. Clean the contact after opening fromthe right side.
Posted on Jul 17, 2007
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Cuisinart tob-30bw,is not starting ?when i try to toast its not working
The problem is 4 capacitors on the small circuit boards inside. Three 220uf 16V and one 1uf 50v. These apprear to be going bad from internal heat drying them out and they fail. Symptoms include toast will not start when button pressed, or does start but then stops soon after. A buzz or hum heard when the Toast selection is made..(you should hear nothing until the start button is pressed) and the timer beeper no longer working. These are about $2 in parts, and easy for a good electronics person.
May 06, 2010 | Cuisinart TOB-30 Toaster Oven with...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Button to toast won't latch
THE BOARD IS BAD .the problem is b&d will not sell it to you . i had one that i DID FIX , there was a problem in the power supply on the board , i checked out the parts i needed there where 2 diodes , and an scr transistor i found bad . ordered them (with shipping 28.00 ) got them and installed . and the first power up POP the ic timer blew apart and damaged the two diodes . cost of the ic another 25.00 plus the other parts. so i now have around 60.00 in parts and 4 hours labor in to my great working 7 year old toaster oven ( that i only paid 25.00 for in the first place ) so unless your like me and never give up ,NO MATTER WHAT ! its time for a new toaster oven ......... if this answer helped please rate a 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Jun 19, 2009 | Black & Decker TRO360 Toast-R-Oven Toaster...
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
Black & Decker TRO651 Toast-R-Oven Toaster Oven with Convection Cooking Logo
556 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
