Question about Neff Ovens
What oven setting should I use with the ceramiclean option?
How do you set the clock?
Since you didn't state your oven name and type,what you can do is google it.just do this as a example,k.How do you set a clock on a Kenmore oven?Then select from the options and their should be one to show you how to set your clock.
Jul 18, 2015 | Ovens
Used the self cleaning option and now top oven will not heat?
Good Morning Friend,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
-Best Regards-
WP
I have an old electric oven. Somehow after touching the timer settings the oven will now not work. What do I need to set the timer options to. The timer is adjusted using knobs - one for the clock and...
The timer must be in manual mode for the oven to work. Turn the oven ON. With the oven turned on make adjustments to the two knobs. These are generally stop/start timers. These turn and you can also normally press them in. Be patient. When the oven indicator light comes on it will be fixed.
Mar 02, 2011 | Ovens
The temperature printing on the fascia of the oven around the knob has worn away. What can I do to find the oven temps?
Place an oven thermostat in the oven compartment, this will give you a reference point from which you should be able to determine the various settings to set the thermostat to.
The only other option is to replace the facia panel
Jan 08, 2011 | Ovens
Please could someone tell me how to use the grill?
First things first, the grill only works with the door down. Directly you shut it, a microswitch operates and shuts the elements off. ( Of course the top oven operates with the door shut).
There are two options for the grill. Turning the control switch to the left operates the inner element only. Turning it to the right operates both the inner and outer elements together.
With either option, setting 5 (the max) has that option on full, whereas settings 1 to 4 switch on and off.
Nov 10, 2010 | Stoves 720EF Electric Double Oven
I have a Kelvinator (used) self-cleaning oven with no manual. I would like to know how to set the dials for cleaning the oven.
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 27, 2010 | Ovens
How do i set the delay start option on my oven?
We need the model number to find the right manual. You could try looking it up yourself here: http://www.managemyhome.com/mmh/
On the right-hand side of the page, under "Owners Manuals", type in the info. If you don't find it there, then please tell us the model number and we can look some more.
Mar 16, 2009 | Ovens
Ovens Logo
55 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
