Question about Whirlpool Dryers
Leaking dryer Our Whirlpool AWZ 8812 dryer has started leaking. The dryer itself is still working, but not how it supposed to. The Top water container is not filling up with water. There is a little bit in it, but 98% is coming out of the heat exchanger. The heat exchanger is clean, the filter has been cleaned after every cycle and the pump is working normally. Any idea what it could be and what to do? Many thanks, Marlien Jones.
3 Suggested Answers
  • 77 Answers
SOURCE: Whirlpool AWZ 8577 Tumble Dryer The water is
You have a water pump in the base of the appliance this can sometimes fail or block. On the back of the dryer there should be a pipe just pull that off and blow down it, if there is a block this may well remove it. If not it's likely a pump failure.
Hope this helps
Posted on Mar 20, 2010
SOURCE: I have a Whirlpool AWZ 8578 which is only four
I'm having exactly the same problem. Mine is about 16 months old though. Anyone have any ideas?
Posted on Nov 28, 2010
Whirlpool AWZ 7686 Tumble Dryer heater works for only 10seconds
Might want to check for an obstruction in the outlet of the exhaust
Well if you had mention that in the first place I wouldn't be asking you. No wonder your trying to fix the problem by yourself because with that attitude you can't get a technician to come out for service.
Sep 12, 2015 | Whirlpool Dryers
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool AWZ 8578 - does not stop, always needs manual switch off
These symptoms most usually are a bad timer/control. If the dial turns all by itself, and continues to turn by itself like a clock does, it is likely a timer/control must be replaced. Same results if it will not advance by itself either.
You could type in "Sears Parts" for the new part, typing in your complete model number. If you wished to try a used control, after obtaining a part number, you could type that in to "e-bay" and see what you find in new or used parts there. I do.
Be blessed.
Feb 15, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
I got a Whirlpool AW Z 865 dryer. It is a condenser dryer and the water is not going up to the collecting bucket, but remains below and then leaks out and floods the floor when I open the little pull door...
I had a similar problem with a Whirlpool AWZ 8578 Tumble Dryer. The solution was to clean the fluff out of the rubber grommet in the drain hole under the left front of the condenser. Then the water from the condenser could run into the collection container underneath.
Nov 25, 2010 | Whirlpool Dryers
Whirlpool AWZ 8577 Tumble Dryer The water is not collecting in the top water container
Hope this helps
Mar 20, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirpool AWZ 480 dryer
It could be as simple as a door switch adjustment. Get it fixed under warranty.
Sep 12, 2017 | Whirlpool Dryers
Open Questions:
Dryers Logo
191 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
