Question about Garden
Husqvarna 235 fuel tank line replacement - Garden
steve_lima
  • 181 Answers
SOURCE: How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Posted on Feb 11, 2009
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 65 fuel line
This is Husqvarna.com manuals. You wlll need to find the IPL that applies to you. The exploded diagrams should help you trace the fue lines.
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: how to replace fuel line/filter 1994 husqvarna 36 chainsaw?
You can find an IPL with fuel system components, part numbers and some detail here: They are probably spread overr multiple images.
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
typical fuel system:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 13, 2009
nova2nv
  • 197 Answers
SOURCE: Fuel leaking at the fuel filter attached to fuel
The fuel tank vent is whats leaking.Some saws that have primer bulb set up were sent from factory with the primer return hose not being long enough so it will either come off or break at the tank vent/filter.I have seen some saws leak around the tank vent when temps are below 10 degrees F due to tank plastic distorting from the cold weather.
Posted on Feb 22, 2010
SOURCE: I have a Husqvarna model 444 chain saw. The fuel
order new fuel line and filter from www.randysenginerepair.biz
remove top cover, remove air filter, remove fuel line from carburetor, empty gas tank, pull remains of fuel line out of tank and replace with new.
Posted on Nov 06, 2010
HI I have a 235 husqvarna chainsaw how do I replace the fuel lines thank you
These machines have micro bore fuel hoses, they are an interference fit in the tank and are very tight, you have to trim the end of the new pipe tp a point, push it into the top of the tank and use a pair of long nose pliers through the open filler cap to grab the end and pull through.
Apr 10, 2017 | Husqvarna Garden
Husqvarna 235 primer bulb hard fuel tank building pressure and won't start
1) replace primer bulb
2) replace carburetor diaphragms and gaskets, inlet needle, and metering lever
Feb 02, 2017 | Husqvarna Garden
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Husqvarna 42" Yard Tractor YTH1542XP rear fuel line leak
Been looking the parts diagram, it shows 1 line on the tank. Need to replace line.
Nov 24, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
I have a 235 that I am haveing trouble to get it to idel down. Sometimes it ok and other times it reves rightup , then dies down and quits. Need help on how to fix it so it runs right.
Check fuel line and tank vent for air leaks, check clutch springs are not stretched or broken, check ignition module spacing. Possibly clean and service carb.
Jul 31, 2013 | Husqvarna Garden
How to replace carburetor in 235 husqvarna.
before replacing the carb remove the muffler and run it the muffler has a screen inside that gets plugged up with carbon then replace the fuel line from the filter to the carb they crack and **** air instead of fuel
Sep 19, 2012 | Husqvarna 232 235 240 Cylinder Pn...
My Husqvarna 24C fuel pipe in the fuel tank has perished and broken can I replace it and if so how?
Fuel lines are a push/pull fit, the fuel line has 2 flanges, one should sit either side of the fuel tank. I will send you a link to the parts manual.
May 31, 2012 | Husqvarna Forest & Garden 125l 18" Gas...
I have a Husqvarna model 444 chain saw. The fuel pick up line disolved in the fuel tank. How do I replace?
Aug 25, 2010 | Husqvarna Chain Saw 20" Bar
Oct 29, 2008 | Garden
Garden Logo
1,664 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
