Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I have that GE Smart Water Hot/Cold water cooler that seems to be leaking water. How can I get this fixed?
This is a stand alone water cooler that holds a 5 gallon water bottle for dispensing hot or cold water.
SOURCE: the hot water smells like rotten eggs., only the hot water
its the mag rod in water heater-if your not using alot of hot water,and water is sitting in heater it will smell like rotten eggs-u can remove mag rod from water heater.it is in top of heater-
Posted on Jan 08, 2009
  • 659 Answers
SOURCE: elec water heater no hot water
Check the breaker to see if the unit is getting power. You will need a voltage meter to check out the thermostat on the unit and also you will need to use it to check if the elements aren't blown. Sounds like the unit isn't getting power but could be the thermostat located under one of the panels on the side of the unit.
Posted on Mar 20, 2009
jj505
  • 195 Answers
SOURCE: water only stays hot for 5 minutes when I take a shower
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
Please rate Thanks
jj505
Posted on Mar 29, 2009
Bati99
  • 88 Answers
SOURCE: i purchased a whirlpool 40 gallon hot water heater
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Posted on Apr 16, 2009
SOURCE: no hot water running
Teresa, the same exact thing happened to me this morning.... please let me know what you find out.... :o)
Posted on Jan 09, 2010
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Oct 03, 2012 | Water Heaters
I have an GE Waterheater taat seems to be pulling a lot of watts. I had a person from the power company come out to see why my bill was so hi. she said that the ater heater was pulling 4500 watts witch...
the elements are 4500 watts this is what most all heater come from the factory. What you need to check is the amps.
Now with that aside, whenever I have gone to a home and I am told the the water heater is running to much I think leak under the slab. I dont know where you live but if you dont have a basement. I would look hard at that.
To do the K I S S test turn off the cold water feed to the heater tonight before you go to bed. when you get up in the morning feel the hot side and if it cold thats good. Now the test. turn on the cold water valve if the hot pipe starts getting warm or hot you have a leak and the wate heater is running all the time.
Hows your water bill too? higher ?? if so that leans to a leak also
Hope this did you good.
If you need we can set up a phone chat and I can talk to you about how to fix it with out spending over a 1,000.00
Best of luck
Tom
Sep 13, 2011 | General Electric Water Heaters
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
Jul 16, 2011 | General Electric GE SmartWater Household...
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Apr 16, 2009 | General Electric GE SmartWater Household...
GE Profile Smart Water Heater leaking at top/no hot water
could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
Nov 09, 2008 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
65 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
