Question about Toro 53805 Lawn Master II 4-Zone Landscape Sprinkler System Water Time
Why doesn't the selected program show when Run is selected
Shockwave/bug in the game
First, update your java runtime environment software to the latest version for here:
http://www.java.com/en/download/manual.jsp
Then update your Adobe flash player software to the latest version.
For Internet Explorer you need this update:
http://majorgeeks.com/Adobe_Flash_Player_for_Internet_Explorer_d5163.html
For Firefox, Netscape, Opera and Chrome use this update:
http://majorgeeks.com/Adobe_Flash_Player_for_Firefox_Mozilla_Netscape_Opera_d7806.html
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira.
You should be in pretty good shape if you run and install all of these programs.
Sep 07, 2012 | farmville.com
Can not see the page that shows me how many coins i have
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
Make sure to select ALL of the "threat categories" when you install or configure Avira...
Aug 18, 2012 | Mytopia Lucky Slots
Farmville Posts not going to my Home Page like they used to. Where do they go now?
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below..
You should be in pretty good shape if you run and install all of these programs...
Aug 12, 2012 | Zynga Farmville
None of my games are showing a full page
Jul 24, 2012 | Facebook Apps
Cant download
Jul 10, 2012 | Zynga YoVille
In world of battles when i get to the screen with the advisors it doesn't load, help?
Jun 28, 2012 | Computers & Internet
Videos not showing on veveo
Jun 28, 2012 | Toshiba Computers & Internet
Game won't load on facebook, with firefox
Jun 27, 2012 | Zynga Facebook Apps
False high score
Jun 07, 2012 | PopCap Games Bejeweled Blitz
How to uninstall deepfreeze if forgotten password?
What we are going to do is to load a new instance of Deep Freeze login program and we'll change it in such a way that it will accept any password as a valid one.
Let the Play Begin
The first thing to do is to find some data that we are going to use later to load our login program instance. For this, load the Process Explorer. Once it is loaded, we can see a list of all the processes our system is running, among them is the login program called FrzState.exe or FrzState2k.exe. You may expand the tree if required to find this program. Right click over the program's name and select "Properties". A new window will be opened with the process properties.
Under the Image tab, note the property named "Command Line". Note down the value of "Command Line" including the three numbers at the end of the property for future use in this tutorial.
Run Ollydbg.
Quote Note: Make sure that OllyScript is properly installed. Make sure that the menu "Plugins" and submenu "OllyScript" is available. If this menu doesn't appear in the program, that means the plugin is not installed properly. To install it, go to the menu "Options" and select "Appearance". In the "Plugin path" box write the address where you copied OllyScript files, press OK and restart the program.
On the 'File' menu select 'Open' and look for the login program file (remember that Process Explorer told you where it was). In the 'Arguments' box write the three numbers you've written down. Click 'Open'. If a warning message box shows up press 'OK'. If a message box is encountered with the content "Do you want to continue the code analysis?" - press 'No'.
We have successfully loaded the program. However the problem we face here is that it is protected with Aspack 2.12 due to which we cannot see the real code. To solve this, we are going to use OllyScript and the ASPack 2.12 OEP finder script. Go to the "Plugins' menu, and then to the "OllyScript" submenu and select "Run Script".
Look for the script and open it. The script will find the OEP (original entry point). If any window shows up dismiss it.
Quote Note: We are now on the OEP. If you are an experienced user you can dump the program using OllyDump to analyze the code with a disassembler.
Right click over the code and a context menu will appear, select 'Go to' and then 'Expression' (or use the shortcut Ctrl+G).
In the text box enter the following value according to the Deep Freeze version you have installed and press OK.
VERSION/VALUE
4.20.020.0598 / 40368D
4.20.120.0598 / 40368D
4.20.121.0613 / 4034F5
5.20.220.1125 / 4037E9
5.30.120.1181 / 4037E9
The program will jump to the line of code.
This is the line from where the password verification procedure is called. Let's set a breakpoint here. To do that right click over the line and in the context menu select 'Breakpoint' and then 'Toggle' (or press F2).
We are almost done! Now let's run this new Deep Freeze login program instance. To do that press F9. If everything went right now you should see two Deep Freeze icons on the system tray next to the clock. If Deep Freeze was configured to hide it , instead of two icons you'll see an empty icon.
Quote Note: If the icon doesn't show up is possible that you haven't written the argument three numbers correctly or that you haven't opened the right file.
Now activate the login program by double clicking over the icon while you keep the shift key pressed. If there are two icons, is important that you click over the new icon and not over the old one. The login window will appear asking for the password. Write anything in the password box and press ENTER. The breakpoing we set earlier in Ollydbg will activate and the login program will freeze.
Quote Note: If the breakpoint doesn't activate is possible that you've chosen the wrong icon. Try with the other one.
On Ollydbg press F8 to step over the function call. On the registers window (to the right of the code) you'll see that EAX register has the value 00000000. That means the password is incorrect, let's change that. Double click over the value of EAX to open the modification window. In the 'Hexadecimal' text box write 1 and press OK.
Now press F9 to continue. If everything went right the Deep Freeze configuration dialog will show up.
Sep 04, 2011 | Microsoft Computers & Internet
Toro 53805 Lawn Master II 4-Zone Landscape Sprinkler System Water Time Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
