Question about RCA EZLINX 3 BNC male plus 2 male to 13-Pin EZLinx Male connector Multimedia Projector
No sound on my kam uhf wireless mike
Unit lighting up - handset showing on, battery new, but for some reason sound has dissapeared - any ideas?
  • 2,237 Answers
Wire loose inside handset, or receiver output problem. wiggle the handset wires and listen for crackling. if so, repair or replace.
Posted on Jan 29, 2010
How do I shut off the Light "in use" when the phones are not in use?
If you have "wireless" telephone handsets, pull the batteries out of one unit, and then check that "in use" light. Repeat with the next handset, until the "bad" handset has lost its battery, and the "in use" goes out.
Oct 30, 2014 | Lands Phones
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
My Samson Airline UHF wireless kit is not working. I have all new batteries, cables and all the lights are on, except on the AG1 transmitter. When I turn it on, the light comes on, pops and then goes off
Make sure you are using ALKALINE batteries... rechargeables have lower voltage that does not work with a lot of these devices... Often the batteries are marked with the voltage they are intended to replace rather than their actual voltage. NiCad batteries only produce 1.25 volts and that is under what is required. The device will come on and immediately go off.
Mar 05, 2011 | Samson Airline AG1 UHF GuitarBass Wireless...
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I took the post that mentioned removing the battery, waiting a few minutes and then reinserting it.  It worked.  Thanks to that person.
Apr 14, 2009 | Uniden Cordless Phone
Mouse cursor flickers and dissapears on Football Manager 2009
Hi, have you check the mouse setting in the control panel?
I think your mouse has a problem if you can verify that the setting is normal.
I would suggest you try with different mouse to narrow down the problem.
Hope this help.
Kam
Dec 08, 2008 | Sony VAIO VGN-FJ270/B Notebook
2000 lincoln ls i got a trouble code p1633 (KAM)voltage to low
P1633 means KAM (Keep Alive Memory ) Voltage too low. the KAM is caused by low battery voltage and you replace the battery.When you replace the battery the KAM loses Memory and the problems resulting in what you are experiencing now.When replacing a new battery, reconnect the Positive cable first.And use a trickle battery charger set low to the cables before disconnectng the battery . this will keep the voltage to the ECM powered with enough voltage. All you can do now is make the computer relearn the way it should run. Disconnect the negative cable from the battery, wait a while 20 seconds or so. then reconnect the cable. I do not know if this is a temporary fix or not but it should re-program the computer.
Nov 19, 2008 | 2000 Lincoln LS
Response
If I knew you were looking, I would have suggested Sennheisers in the first place.
Aug 25, 2008 | Shure SLX UHF Headset Wireless System...
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
61 people viewed this question
Top RCA Office Equipment & Supplies Experts
jasbo
jasbo
ray gallant
Are you a RCA Office Equipment and Supply Expert? Answer questions, earn points and help others
