Question about Sony Audio Players & Recorders
I need a manual/instructions for a Sony Walkman FM/AM WM-FX405
AThe Sonydding details will get you a faster solution from experts
SOURCE: URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
Posted on Sep 14, 2008
SOURCE: Sony Walkman WM-D6C
If your WM-D6C has a serial number below 267201 (take out the battery block and you'll see the serial number sticker there) then the problem is electronic, not mechanical. It is likely due to the speed controller chip (labeled as IC601 on the circuit board), which is made by Sony and is type CX20084. This chip decides the voltage that is fed to the motor which is only about 2.4 volts, Should the chip be defective then the motor receives about twice this voltage and thus runs too fast. If you take the back off the recorder you will see the circuit board; it looks like a rectangle with a small square extra bit sticking out to the right. It is here that the IC601 resides. It is about the size of a small pinky finger nail and has 8 tiny legs down each side. Measure the voltage on pin 15 (put one voltmeter probe (+) on the second leg down on the right side (pin 15) and the other one (-) on the battery negative), it should read about 4.8 volts, which it feeds into the base of transistor (Q601) that in turn will then feed 2.4 volts to the motor (if everything is working OK). If the chip is damaged, then the voltage on pin 15 will be close to zero, and the transistor Q601 will not be "held back" and so will feed about 5 volts to the motor. CX20084 is (unfortunately) obsolete, someone in the UK sells them for about $50, but an excellent company in Hong Kong (utsource.net) sells them for $5 (plus $8 S&H). Taking out the old chip and putting in a new one is close to microsurgery, you will need a micro soldering iron (18Watt Antex), a good eye, a powerful magnifying glass and a steady hand, but it can be done - I've done it! There is a possible second reason that could cause the motor to run too fast. There is a pick up coil on the main flywheel called FG901. If this is damaged it will be open circuit and then the only use for your recorder is probably a paper weight. You can test this by going back to chip IC601 and locating pin 1 (top left pin; a small circle on the body of the chip is next to pin 1), Pin 1 is connected to the positive side of a capacitor,  C602 (0.47 microF), check the resistance from the negative side of C602 to the ground (take battery out, and use battery (-) as ground). You should get about 600 - 650 ohms reading. If you get nothing, sorry there is not much you can do about it as these pick up coils are definitely not available. Finally, chip 601 (CX20084) goes bad if you connect the batteries back to front. Good luck. Giles..
Posted on Jan 16, 2009
caroldon
  • 17129 Answers
SOURCE: I have a sony walkman WM-3. It suddenly stopped
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Posted on Jul 21, 2010
caroldon
  • 17129 Answers
SOURCE: how to replace the drive belt on the sony walkman
Since this is a very small player what is important is to be very careful and delicate to open the rear cover and do the repair. The printed circuit board has to be removed and moved up carefully not to damage or detach wires. Now remove the capstan cap and take out the old belt, check the size with the new one and if OK run in the same direction you had taken out. replace the lid and the pcb carefully and fix the wires according to the same pattern so as not to touch the belt and drives. Now put in a cassette and test. If it works ok with the speed close the rear cover. clean the headd, the rollers and the transport section . Now your tape has been serviced and must work well. Hope my advice helps you . Good day
Posted on Jul 22, 2010
  • 186 Answers
SOURCE: how do I dismantle a sony wm-ex39 walkman. I
i had this problem.i use a knife to pry it open
Posted on Oct 17, 2010
How to tune my sony walkman fm/am preset
Does it have buttons 1-6 on it????? If it does try going to station and try pushing and holding button one.....until it stops blinking.....
Mar 23, 2012 | Sony Walkman WM-FX290 Personal Cassette...
I need drive belts for Sony Walkman AM-FM tape player
call 1-800-488-7669 for walkman parts mon-fri 8:00am - 12:00am ET sat-sun 9:00am - 8:00pm ET
Feb 04, 2011 | Sony Walkman WM-D6C Personal Cassette...
Please can you send me the user manual for Sony casset/radio modal WM-FX 277 thank you
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-find.pl?mdl=WM-FX277
Aug 11, 2010 | Sony Walkman WM-FX277 Personal Cassette...
While trying to rewind or fast forward, it stops before reaching the end, and I have to restart it.
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Dec 10, 2009 | Sony Audio Players & Recorders
Turn walkman off
If it's a tape player with a stop button it should turn off by just pressing stop. If there is a radio then there then there should be an off position where you select if you want to listen to the radio or listen to the tape.
Jan 19, 2009 | Sony Walkman WM-FS399 Personal Cassette...
My Sony Walkman WM -SR10 is not recording and the cassette tape is not working. Only the radio is player. And I cannot get another one to buy even its not the same. Can you help me
Hello aga2958,
I think you need to visit maintenance center to fix that cause its hardware problem.
But you can check somethings before u visit them .. like:
1. If you are using Batteries to power up the Walkman .. be sure the batteries are full charged.
2. Try to power on the Walkman by Adapter 3 Volts.
3. Be sure the tapes you are using are fine into other Cassette.
Thanks for using FixYa.
Nov 09, 2008 | Sony (Personal Audio) Walkman AM/FM Stereo...
Need instructions on how to use my walkman
I have this walkman too and also need the instructions. I found them at this website:
http://www.docs.sony.com/release/WMFX290.pdf
I hope that helps you out!
Aug 07, 2008 | Sony Walkman WM-FX290 Personal Cassette...
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
