Question about SanDisk Sansa E280 MP3 Player
Sansa e 280r is not being recognised by my computer
I have a sansa e 280r model player and when I connect to my computer the same is not being recognsied. kindly help me out
  • plow Jan 31, 2009
    my sansa e280 is frozen, the blue light on the wheel comes on but that is it
    Brian
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Jan 29, 2009
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
Apr 08, 2010 | SanDisk Sansa e260 MP3 Player
Computer doesn't recognize MP3 player -
Check My Computer. If the PC recognises the Sansa player then simply add the songs by dragging the files into the player's icon on My Computer. Sometimes this kick starts the built in software included on the mp3 player.
Apr 01, 2009 | SanDisk Sansa Clip MP3 Player
Sansa e260 not recognise,cannot format it
Ok first try to calm down, take a look at the back of the player and you will see 4 very small phillips screws, remove these and take the battery out of the player for about a minute then put it back in and see if all is ok, this will most times solve all problems but you may lose some if not all of the content in the player.
Feb 23, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260. Black Screen. Glowing Light (constant) Not Recognised
The volume + method should force recognition:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jan 09, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip not recognised after formating
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Nov 18, 2008 | SanDisk Sansa Clip MP3 Player
Connecting Problem
Unplug your Sansa. Uninstall all the Sansa software from your computer, and reinstall the clean version from the Sandisk website. Then, replug the Sansa.
-Tha Mp3 Doctor
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
C150 frozen
re: frozen player, follow the steps outlined here
Oct 06, 2008 | SanDisk Sansa c150 MP3 Player
Sansa clip mp3 player
check drivers in xp or windows
do u have drivers cd ,
download drivers n install it.
ur's kishore chowdary +919441133420
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e250R rapsody mp3 player
Get software from Sandisk's website
-Tha Mp3 Doctor
Apr 16, 2008 | SanDisk Sansa e250 MP3 Player
PC can't recognise e260
-Tha Mp3 Doctor
May 14, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
379 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
