Question about Maytag Washing Machines
Shake bad tub is tight
    Sergeant:
  • 291 Answers
Is there a sloshing sound when you move the tub sort of vigorously back and forth? If no slosh suspect the balance ring.
Posted on Jan 20, 2013
Washer clothes
Your load is out of balance.
If you have a heavy item, spread it around the tub to balance the load.
It is normal for the tub to shake during the spin cycle. The washer has a safety feature, if it is too badly out of balance it will shut itself down and sound an alarm.
Jun 01, 2014 | Whirlpool Refrigerators
Altima engine shaking
AC compressor put load on engine causing engine shake vibrate.but check make sure AC compressor mounting bolts tight and drive belt correct tension.now if AC compressor very old most time bad compressor cause more load on engine causing shaking real bad.
May 23, 2013 | Cars & Trucks
Shakes bad
Is this a washer? You posted under the Kitchen Range forum.
Jan 20, 2013 | Maytag MER5775Q Electric Kitchen Range
Lifters sticking cleaned and now it shakes real bad when it is running.
If this is a 1.9 ltr you need to remove and compress all the lifters they are too tight and are holding the valves partialy open if this is a mazda engine simply adjust the valves if the lifters are pumped up
Jan 03, 2013 | 1997 Mercury Tracer
The wasing machine shakes badly when in a spin cycle.\r\n970-C45092-00
Hi
First check if the machine is level .Also makes sure you do not have an unbalanced load. Lint filter between the tubs is loose/broken, tub nut and drive block is worn, bad brake, worn spin tub are some various reasons when washer shakes in spin cycle.
Please check the bellow link to troubleshoot your problem:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Kenmore Washing Machines
Shakes and walks like hell when on spin. Have check if level and feet are tight Thanks regards Peter
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,<br />When my washer did that, I found that the shocks that hold the tub were bad...<br /><br />Check out this tip I wrote about the noise and vibration that front load washers can make..<br /><br />Washer Problems Washer noise when spinning<br /><a href="http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when" target="_blank">http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span><br />
Aug 27, 2010 | Maytag Performa PAV2200
Washer goes off balance so easily, no matter the size of the load, from towels to shirts. We checked the washing machine itself is level. It's so frustrating to have a small to medium load cause the basket...
The tub is out of alignment.The suspension springs are weak and must be tight, the tub must not shake,if so the dampers are faulty.
This suspension must be so rigid that it must not shake around freely . check the pulley arangement , the bearings at the bottom spindle, if out of balance. If there is any anomalies in this ddrive section it must be observed and checked.
A careful analysis is most important to having a first hand information.
Aug 23, 2010 | Maytag HAV2557 Top Load Washer
Replaced Transmission: everything working great, just not sure about suspension springs. 3 are very tight (tub base), 3 are somewhat loose (metal hangers). Is this normal?
If you can shake the outer tub in several directions without it banging the mechanism on the case, it would appear that you have it correct. If it were wrong, either the machine would 'walk' around the floor or make banging noises when it goes into spin with a full load of clothes. The tub should be free to shake, but in a controlled manner. Good luck and well done!
Mar 17, 2010 | Washing Machines
Kenmore Elite tub shaking badly
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine shakes violently
There is the tub that spins on the bearing the " the active tub"(the one the clothes go in obviously) and around that tub is the "stationary tub", between the two are what they call "snubs" these are either rubber wheels, bushings or on cheaper models just a rubber boot that works as a shock absorber if you will, and keeps the movement of the the "active tub" with in its axis. If a wheel is broken, or a bushing/boot is torn or broken then there lies your problem.
I hope this helps.
Aug 06, 2008 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
