Question about Canon LaserBase MF5650 All-In-One Printer
Not sure where leads go from pc and modem to fax
I have a printer/fax in one. a bt modem and pc. I have moved office and I am not able to send faxes. Phone works , printer works internet works but not fax!!!!
  • Soulvisitor
    Soulvisitor May 11, 2010
    same as your other 3 posts, is fax line out connected to direct phone socket?
  • 2,120 Answers
Phone cord gets plugged into the LINE port.
Posted on Jan 26, 2009
Sending fax displays comm.error
There are many things that can interfere with proper sending of faxes. Has anything changed in your office recently? Phones changed? Did you recently get DSL service from your phone provider? If so, you probably need a DSL filter on the line going to your fax machine. Try faxing to different faxes to make sure that it is not the person you are sending to that has the problem. If you are using Voice Over IP or VOIP phone, good luck, as older fax modems do not always play nice and you will likley need to speak with your VOIP provider to ensure they have their lines configured. If nothing has changed in your office then perhaps your modem has just failed, it does happen. A new cord between the jack and the machine is a a cheap test as well. If you have a telephone, unplug the fax and plug in the phone and see if you can make a call.
Sep 04, 2014 | HP LaserJet 2840 All-In-One Printer
Lexmark 5250 won't fax. I have installed everything several times but says something about OCR not working. It will scan & print instead of sending document to Fax. I can open Fax window, but...
Use the Lexmark All-In-One Center application to send faxes from your computer (make sure your computer is connected to a fax modem). From the Creative Tasks section of the All-In-One Main page, click Fax using PC modem. Follow the instructions on the computer screen.
Jul 25, 2011 | Lexmark X5250 All-In-One InkJet Printer
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Can dial out and receive incoming calls but will
Are you connected to a VOIP line for your fax?
A VOIP line can come from a company like Vonage or your local cable co.
If so:
Unfortunatly, faxing over VOIP (Internet) is not always successful. You might want to talk to your VOIP provider if they have a solution.
If not:
Are you trying with the same fax to send and recieve? Some traditional fax machines have probles connecting to fax modems, which is what you have in an Office Jet.
Try having someone else send you a fax and try sending to another number. Otherwise, you might have a defective fax modem.
Nov 07, 2009 | HP Officejet 7210 All-In-One InkJet...
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
How do I send a fax through Samsung MFP from my PC?
You need to install the smart thru office either from cd or from downloadable site. You must have a fax modem for your pc.
Jun 16, 2009 | Samsung SF-565PR/XST Printer
Hi there. I have just taken over this office and am not sure what is connected and what is not. I am trying to send a fax through my computer and the "waiting for printer to respond:Canon MP830...
you need to give more details on how you're trying to send the fax.
keep in mind you don't actually need a printer to send the fax if you're using your computer to send the fax.. that's the reason you need to be more precise when discribing your problem.
in general you need to be familiar with how things are connected.
if your printer is a fax machine too the minimum you need is to have your printer/fax connected to a line (to the telephone wall jack) and to be powered up.
if your printer is only a printer and you're using your computer to send the fax you need to have your modem (the connector in the back of your computer that looks like a telephone line but says not telephone but 'line' connected to the phone line on the wall) connected and have software that allows you send faxes via your computer. (windows xp has that software so you need to make sure is installed (start>control panel>add remove programs>add/remove windows components>fax services should be installed) and if the software is installed you should be able to go to start>accessories>communications>fax>fax console
confirm what is your set up and give more details.
Oct 17, 2008 | Computers & Internet
Hp printer set-up
The fax is plugged into the telephone line, not your modem.
Jul 07, 2017 | HP Officejet 4315v All-In-One InkJet...
Sending Fax
make sure you phone support fax.
if support you just pair it with pc and it should have install phone modem driver. used the modem as your fax out line.
Apr 09, 2008 | Nokia 6120
My fax sound but dont received any fax
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon LaserBase MF5650 All-In-One Printer Logo
42 people viewed this question
old marine
old marine
