Question about Graco Baby Gear
Arm Bar on Graco Mosaic Pram
We would like to know if there is anyone who can help us figure out how to open the arm bar on our Graco Mosaic Pram to make it easier to get out little bundle in and out as she is getting sush long legs even though she is only still 5 months old - bless
Any help would be gratefully received
Serial No' 0115080119
Model No' 7HG3CCLU
I think it is on the right side if you are facing the stroller, underneath there is a small button you push and the bad will swivel. I think the button is black so you might have to look closely.
Posted on Jan 30, 2009
HOW TO REMOVE A LOWER LEFT CONTROL ARM AND TORSION BAR
jack the vehicle right up so that the the wheels are clear of the floor . Place vehicle on jack stands
release the tension on the torsion bar by removing the adjuster in the arm. you may have to use Stiltons or pipe wrench to get the last bit of tension out of the bar . remove and retainers and tap the bar out of the splines.of the lower control arm. mark the bar so that you will know which spline to use for reassembly
remove the lower control arm.
Mar 02, 2015 | 2004 Ford Explorer Sport Trac
Control arm
Control arms are the parts that hold the ball joints (upper and lower) and attach to the vehicle frame. Look in back of the tires. The lower control arm, in your case, will have a torsion bar (a bar that serves as a spring)making the repair more labor intensive. Cost will vary based on labor rates, parts cost/mark up. Sorry I can't give you a figure but hope it helps at least to identify the parts.
Jun 16, 2012 | 1995 Chevrolet Blazer
Graco replacement handle grips required
A replacement hand grip for bar for a graco pram.
May 25, 2011 | Graco Mosaic Travel System Stroller
How do I. Get the lower control arm off my 01 stratus
SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS. MAKE VECHICLE SITTING ON LEVEL SOLID GROUND. REMOVE FRONT WHEELS , REMOVE HEAT SHIELD, IF EQUIPPED WITH 15 INCH WHEELS, REMOVE BALL JOINT CLAMP NUT, REMOVE SWAY BAR TO CONTROL ARM BOLTS, REMOVE STRUT CLEVIS FROM THE LOWER CONTROL ARM, REMOVE SWAY BAR TO CROSSMEMBER BOLTS LOOSEN THEM AND ROTATE THE SWAY BAR AWAY FROM THE CONTROL ARM, LOWER CONTROL ARM FROM STEERING KNUCKLE. REMOVE BOTH LOWER CONTROL ARM BOLTS. REMOVE CONTROL ARM. DURING INSTALLATION TORQUE LOWER CONTROL ARM BOLTS 120 FT LBS. CONTROL ARM STEERING KNUCLE TORQUE NUT 70 FT LBS.TORQUE SWAY BAR BOLTS 21 FT LBS.
May 23, 2011 | Dodge Stratus Cars & Trucks
How to assemble Graco Cleo Pram?
ots actually quite simply so put the pram part on the graco cleo, all you have to do is unzip the stroller back, tuck it inside around the foot board, so when you put the pram part on theres only 1 zip, as before when there was 2 zips it wasn't sitting flush against the foot board you pull out once you unzip the stroller part. if anyone needs help or doesnt understand feel free to contact me at my e-mail address scattyp@hotmail.co.uk for more help *** hope this helps and good luck.
Oct 26, 2010 | Toys
I have a graco mosaic pushchair in brown/ gold i bought it off mothercare but while it was stored in my mums garage a mouse chewed into the bumper bar and i need to replace it jbut cant find anyone online...
try the mothercare catalogue which you can pick up form most shops, if you cant find it in there, then just ask one of the girls who work there, i'm sure they could help :)
Aug 26, 2010 | Graco Mosaic Travel System Stroller
My driver side windshield wiper stopped working. passenger side still works. when i turn it on i hear a clunking sound near the blade. i need to know how to fix this, i don't know if the bar connecting the...
The bar that connects to the arm that connects to the motor came off. Remove wiper motor to get to that connection, Autozone will have that part in there (help) line.
Jan 04, 2010 | 1998 Ford Explorer
My quinny buzz 3 chassis sometimes starts to partly collaspe when in use, especially when weight put on it, i.e when going up kerbs. Any suggestions to mend? I bought it second hand but it is only 18...
the bolts on the side where the lower section meets the arm need to be checked and tightened as these lossen i have had this happen my self very scary x
i found that every time i opened my pram it would not be fully locked together so i put my foot on the bottom bar and pulled the bar up untill it clicked into place and no longer had issues with it trying to fold itself while in use hope this helps x
Dec 10, 2009 | Quinny Buzz Jogger
Britax preview stoller
I figured out how to take the clips off to remove the arm bar. You go under where the cips are and pull the clip out thenpush it up.
Oct 04, 2008 | Britax Preview Umbrella Stroller
Baby Gear Logo
134 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
