Question about Saws
Proxxon Scroll saw 28092 model 2004
Dear Sir
I just bought this item from Germany and I need an adapter to use pins with no end,could you help me to solve this problem,I am fed up to look about it in internet with no positive results and Proxxon in Germany have not replied yet.Thanking you in advance,I remain very gratefully yours
  • chimopus Feb 03, 2009
    Dear Sirs,
    I am afraid you did not cope with my question,it has nothing to do with electricity or wall;only looking for an adapter to use normal pinless blades for my Proxxon scroll saw 28092,which only uses pinned blades.Thank you ever so much for rep lying,yours very truly
  • James Thompsom May 11, 2010
    Does the appliance have two round pins that plug into the wall? If so please check to see what voltage is required and if possible the wattage also. I hope I can help you . MC4X4
  • 35 Answers
You might need these, if the saw is a Hegner:
http://www.advmachinery.com/default.asp?pg=products&specific=jnnrmmm8
Posted on Feb 14, 2009
Scroll saw owners manual I can't figure out how to change the blade
most scroll saws have pins on the ends of the blade
the end opposite to the motor is a spring so press down on that end and the blade should come out of the holder slots
Oct 17, 2017 | Blade Saws
How do i replace the blade on my Sears craftsman 16 in. Direct drive scroll saw model no. 113.235501 , please help
the blades will have small pins at each end
fit it in the table end first as this is the end that does the work
then pull the top down to fit the blade in the slot
The top is normally only spring loaded
Aug 08, 2015 | Craftsman Saws
How do I change a saw blade on a scroll saw
Which Scroll Saw are you using...there are multiple brands and multiple models. Help us out and tell us which one you have.
Most of the time there is a clamping mechanism that holds the top of the blade in place. Many models have a door or some access point to the lower end of the blade, too, which you'll have to get to as well.
You'll also usually find that there is some type of blade tension device that needs to be released and then reset before you can install and use a new blade. Make sure the new blade is the same length as the old one, also, make sure that it's the same type of blade, some have a small pin top and bottom, some do not.
Finally, check out YouTube and see if anyone has put up a video for your brand of Scroll Saw. May be the answer.
Good luck and be safe.
Oct 09, 2014 | Saws
How to install blades
Almost all scroll saws use a 5 inch blade. You need to take all the tension off your saw before installing the blade. Make sure you are using the right kind of blade. Either it is a pinned blade or non pinned blade. Some saws can use either. Make sure the teeth on the blade is facing down toward your saw table. Clamp the blade into the blade clamps and then add the tension. You should be ready to go now
Jul 12, 2014 | Saws
The rail on my FKS/E Proxxon table saw splays out at the end so precise straight cuts are difficult. Is there an attachment available to clamp on for the full length of the table, or some other way to
There should be a screw on the front end of the rail that can be loosened and adjust the guide straight and then retighten. Sometimes the screws are on top of the guide to do the same thing..
Mar 17, 2014 | Proxxon 38070 FKS/E Table Saw
Inserting the blade on the Proxxon DS/230E I can't get the top of the blade to tighten no matter what I do. I have bent or broken six blades (so far). I can get the blade in the base, tighten the screw,...
If you haven't watched this video, you may want to check it out, just to make sure that you are following the procedure. From what you have said, you are doing it correctly, but perhaps by watching it, you may catch something that we are missing.
http://www.proxxon.com/eng/html/27088.html
Is it possible that the 3 position head is in the wrong position? I am sorry, but I have never used this peticular scroll saw. Please let me know if you still have a problem with it.
Nov 22, 2010 | Saws
MBS 240/E proxxon bandsaw
the 24 TPI is the one to use. It sounds as if the blade is running to fast and over heating the blade and causing it to lose the temper in the balde steel. Try slowing the blade speed down if you can. Also you can try putting some cutting oil on the balde to stop it from clogging up. You can also rig up a small air line to blow on the cutting area to cool it down and remove the metal chips. I've also applied some wax to the blade every so often. A candle will work for this too. Hope this helps you, Jeepfxr
Jan 10, 2010 | Proxxon 28174 24-Tpi Fine Toothed Band Saw...
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Saws Logo
227 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
