Question about GoVideo Go Video DVD/VCR Combo
I was trying to one touch copy a VHS to DVD (DVDR+), but can't proceed past the "initialization".
2 Suggested Answers
battlesmith
  • 382 Answers
SOURCE: I know how to copy
yes you can copy Dvd to vhs..hope the following link will be of some help on that..
http://hometheater.about.com/od/dvdrecorderfaqs/f/dvdrecgfaq2.htm
Thank you!..
Posted on Aug 09, 2008
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
How do i record a vhs to dvd?
Unfortunately you are not able to record a VHS to DVD on this player.
It does not have the capability to record DVDs, in order to do that, you will need a DVDr
(DVD Recorder)
Hope you found this helpful.
Mar 17, 2011 | Philips DVP620VR DVD Player/VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Want to copy vhs to dvd
just play your movies from vhs iput your audio/video to computer with TV CARD and video input. then record it and burn to DVD format after recording.
May 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Magnavox zv420mw8
Are you trying to copy a DVD to DVD. Because I think if you are then it won't work. It might copy it to VHS VIDEO. But that wouldn't be worth it as you would lose quality. Try finding DVD CLONE for your PC.( It might be a free download) Look for it on the net. It will copy dvd to dvd and it's less complicated. I hope this helps.
Jul 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Ilo DVDR 05
http://www.retrevo.com/support/CyberHome-DVR-1600MU-DVD-Players-manual/id/534ci862/t/2/e Someone said these were similar. Try the red/yellow/white cables. select that SOURCE. first select your recording length. I usually put mine on 3-4 hours and try to keep it from running to the end or you have problems. I use Rewriteable dvds, if you use reg discs be sure to finalize the disc so it will work in other players. I read if you are copying macrovision vhs to use the antenna input and it will copy it with that input. Just tune it to channel 4 or whatever. Forget trying to set the timer to record from tv. I never have success with that.
Jun 19, 2008 | iLO DVDR05 DVD Recorder
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
18 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
