Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFF1201 Washing Machine, wont drain
My Bosch WFF1201 washing machine wont drain away the water at the end of a wash. It just stays there in the drum. When you try to get it to drain it makes a very load clicking noise which just is not right!! All the other modes are working just not the draining. How can I fix this?
  • 4 more comments
  • Daryn001 Mar 21, 2009
    With regards to cleaning the filter, do you just pull that plastic thing out that screws out? Is there a second thing to screw out?
    If the filter is clean, what else could cause the problem?
  • jkoron Apr 02, 2009
    I have the same problem with water not draining in a Bosch Axxis WFL 2060. I cleaned the drain pump, as specified in the owners' manual, but the problem recurs about every other wash.
  • phenyl Apr 14, 2009
    Our Bosch also refuses to drain at the end of its cycle, although there are no clicking noises.
    We had a repairman out this morning to fix it (it previously was unable to drain, PERIOD) and he found two pennies that he said were the problem. He also said there were no other blockages.
    As soon as he left, I ran the washing machine cycle to check for problems. While setting the machine to "drain" now drains the machine, it still won't drain automatically at the end of a cycle. What else could be wrong??
  • BaileyK May 03, 2009
    I just purchased a used one and it does not seem to drain everything because after a couple of uses I had to use the manual drain tub on the bottom right side of the unit.
    I checked that is was leveled corrected and that seems fine. I will check the filter next to see if that is the problem. Everything else seems to work fine.
  • BaileyK May 11, 2010
    barkencoa,
    I removed the plastic panel in front of the washer. On the right side you see the part that can screw out and of course the house you can use to drain the water.
    Where is the filter and pump housing? Do you have any pictures to show? I can upload a picture if needed.
  • Anonymous Mar 18, 2014
    My washer will start and fill with a little water then do nothing bit make clicking sounds as if its going to start washing bit won't do anything bit click what should we do to fix this or what could be wrong
  • Bosch Master
  • 3,463 Answers
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Posted on Jan 26, 2009
Not drain water
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Jun 02, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
My bosch classixx 6, 1200 express washing machine keeps displayin
Bosch classixx 1200 express washing machine won't drain
Mar 29, 2009 | Bosch Washing Machines
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
My machine fuses the whole house
water leaking onto the main motor appliance doctor
Feb 01, 2007 | Bosch WFL 2063 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
933 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
