Question about Viking VWH3010 Kitchen Hood
Viking hood no lights...fan works
Lights went out at same time...fan still works, hood about 5 years old.
maklean
  • 1665 Answers
SOURCE: Viking hood Lights out
Have a look at your manual (troubleshooting)
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m2100085_f20469.PDF
Posted on Apr 05, 2008
SOURCE: Viking 10 inch hood lights out
i have the same problem what is it
Posted on Oct 21, 2008
  • 10865 Answers
SOURCE: Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Posted on Feb 01, 2009
  • 6 Answers
SOURCE: viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Posted on Mar 17, 2009
Viking Professional VWH4848 fan hood not working
Have you tested with a VOM to see if there is juice at the plug in question? If not, trace it back to the control/switch area and test there... Careful!
Mar 16, 2009 | Viking VCSF036SS 36" Professional Free...
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
It is more than likely the dimmer switch has gone bad and needs to be replaced
Nov 06, 2008 | Viking DTWL4848 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Viking VWH3010 Kitchen Hood Logo
62 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
