Question about Casio Exilim Pro EX-P600 Digital Camera
Dial Doesn't Work
I have a 3 year old EX-P600 that has stopped working partly. The dial to change to different modes doesn't change to every mode and the right and left scrolling button to go through menus doesn't work either. Can anyone help? Thank you, Pat
    Genius:
  • 2,985 Answers
Dont think you are going to be lucky here. This is a switching problem and a repair is not going to be a viable proposition. Check out the Casio web site Tech Support- but I fear any repair they will ofer the price will be a good proportion of the next[uptodate] camera
Posted on Jul 16, 2007
I can't descale my C5
You may need to go into program mode and "tell it" you replaced the filter. We normally do this when we replace water filters in Jura's. On the f60 you get into program and scroll using the water volume dial and push it in to set the changed value.
Hope this helps
Jan 25, 2013 | Jura Impressa C5 Automatic Coffee Center...
My 2004 silverado crewcab battery went dead and was replaced. The Air conditioning system now only blows through the defrost vents and the dial to change the airflow does not work. Can this be reset?
Turn the key on and make sure the blower motor is working. It doesn't matter what speed. Turn the key off. Pull the hvac1 fuse out of the under hood fuse box. Wait five minutes. Reinstall the fuse. Turn the key on, do not start the engine or touch the heater controls. You should hear the heat swiping through the different modes. After a couple of minutes it should stop. Turn the key off then start the vehicle. It may take several tries but eventually it should recalibrate.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 17, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
Just got my dc33... one issue... the dial switch to control btn bare floor / carpet mode doesn't seem holding in it's position when I set to the bare floor mode... it keeps coming back to carpet...
I'm sorry to hear you're having difficulties with your DC33. If you're concerned that the brush control doesn't seem to be staying in position, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to check everything is correct with your machine, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 24, 2011 | Dyson DC33 Bagged Upright Vacuum
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I have a Emerson DECT 6.0 with 3 head sets and i cant get the dial tone back from pulse.
It was easy for my Emerson Dect 6.0 to be switched either rotary / pulse by just pressing the "FLASH" button for 3 seconds until it beeped. Problem solved.
Or if that doesn't work, you have to:
Tone/Pulse
You can switch the dial mode. In most situations the TONE option should be selected.
• Press the MENU button. Select BASE using <FLASH - or - CID> and press the MENU button again.
• Using <FLASH - or - CID> select DIAL MODE and press the MENU button.
• Using <FLASH - or - CID> select TONE or PULSE and press the MENU button.
OR
Press and HOLD the "<FLASH" button for approximately 3 seconds. T (Tone) or P (Pulse) appears in the display.
Feb 12, 2010 | Uniden DECT 6.0 Cordless Telephone...
The whole center turner doesn`t work anymore ,i think i need to buy a whole new middle button
If the dial doesn't spin, then unfortunately your Fuze is physically damaged, and will need to be repaired.
If the dial stopped working on its on, versus not working due to physical damage inflicted by being dropped, abuse etc., and your player is less than one year old, it is covered under SanDisk's warranty service. Email support@sandisk.com to ask about this. They will probably want you to provide proof of purchase (showing date and place of purchase and name of the reseller).
Feb 11, 2010 | SanDisk Sansa Fuze MP3 Player
Nokia 1100 speed dial problem
hi,
1.Take your phone 2.Click menu 3.Go to contacts by scrolling down 4.Go to speed dial
There we can assign the number as speed dial.
May 21, 2009 | Nokia 1100
How can I set tone/ pulse so I can dial out
Press menu and use the arrow down to goto Global setup and press select. Use the down arrow and goto Dial Mode and press select. Use the down arrow to select your dial mode and press select
Jun 01, 2008 | Uniden 5.8GHz Dual Cordless Phone
How do I change the time?
The Macrotel Excel, Macrotel MT-16 and the Prostar 816 are all very similar in programming. The following information should work on all 3 KSU's of any revision or software level.
To Enter programming: Must be done before any programming
Depress # (Programming)
Dial 20 (MMC Disabled)
Enter Password [Default is 1234] {or it may be 4321}
Dial 1 to enter programming mode. Programming mode will turn off automatically after a few minutes of non-use.
Dial # again
Then
To change Time and Date:
Depress
# (Programming)
Dial 55 (YY MM DD W HH MM)
Input new data:
YY= year
MM= month
DD= day
W= weekday [0=Sun 1=Mon 2=Tue 3=Wed 4=Thu 5=Fri 6=Sat]
HH= hour (24 hour mode)
MM= minute
All data must be entered each time or changes will not be saved.
Dec 04, 2007 | Samsung Prostar 824 Keyset Telephone
Casio Exilim Pro EX-P600 Digital Camera Logo
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
