Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
ICE WITHOUT PLUMBING
Can you put crushed ice in it and will that be beeter if your not plumbing it in and how do i turn off 10 min alarm you said would be better thanks again guru
  • 410 Answers
Sean, yes you can put crushed ice in it with no problems, as far as turning the icemaker off on most of these refrigerators there is a slide switch on the right hand freezer wall that say off or on jus tturn to off. if no slide switch then raise the wire arm on the side of the iemaker until it clicks off and thats it! good luck peyton
Posted on Jan 26, 2009
Need instructions for DQ Blizzard Maker
1st add crushed ice and equal water outside the tin in the blizzard
2nd add 3/4 of salt to the the salt water
3rd put the cap on and in a separate cup mix ice cream mix and 3/4 of half and half and mix until completely dissolved
4th put the mix in the tin cup and add the cap
5th stir with flat spinner not the swirly one spin for 10 min when done push ice cream with swirly stirrer
Nov 01, 2013 | Spin Master 1001130 DQ BLIZZARD MAKER
My ice dispenser just crushes ice no cubes
if you can hear the solenoid clunk when you press for cubes then possibly the disengagment arm isnt being moved by the solenoid ,then remove the ice bucket and check for ice build up that also can hold the ice crusher blades in place,rinse it out with warm water to melt any ice build-up,then wipe dry and put back into freezer without any ice so it can get cold again before ice gets into the bucket again and melt so you have the same problem again
Feb 06, 2013 | Refrigerators
My freezer will not make ice. Door will dispense water and crush store bought ice. Tried to leave freezer door open over night to see if line was frozen, didn't help. whirlpool ED5RHA 25.4
most likely problem is the water solonoid valve it has one inlet from the house plumbing and two outlets one for the water dispinser and one for the i/m.very common to have one side work but not the other
Jul 18, 2011 | Whirlpool Refrigerators
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
ICE WITHOUT PLUMBING turn of the ice and fill my own
Thanks Sean good luck with the decorating  have a great day! Peyton
Jan 26, 2009 | Freezers
it really doesnt matter how full you fill the bucket. round cubes will probably dispense just fine if you have access to that shape ice.
One additional thing, be sure to turn the icemaker off to prevent the fill valve from going bad and to keep it from making a loud buzz about every 10 minutes. thx peyton
Jan 25, 2009 | Freezers
Can i put ice in thee ice bucket in my american fridge freezer
you can put ice in the bucket and it will dispense. couple things though. if you use bag ice make sure it isnt wet when you put it in the bucket, the water will leak into the dispenser motor and cause it to short out also the ice will clump up causing the bucket to possibly break. if you are using ice out of a plastic tray dont try to use the crushed ice feature it also c an cause the bucket to possibly break.. peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Admiral/Maytag fridge/freezer gc2227cdfb
no the water does not have to be plumbed in for the frige to cool. replace bulb. if short in the system exists then you will need to replace an interal wiring harness.
Jan 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
