Question about Kohler Plumbing
Sticky faucet bonnet on my bathroom sink - Kohler Plumbing
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
  • 251 Answers
SOURCE: bathroom sink faucet,(washerless) has a drip when
http://www.housetask.com/Leaky_Faucet_Repair.htm
a repair kit/cassette
most decent plumbing centres will be able to match up the old cassette
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
Dplumber
  • 119 Answers
SOURCE: One of the handles on my Kohler faucet does not
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Posted on Sep 08, 2010
  • 377 Answers
SOURCE: I have an American Standard bathroom faucet. The
Assuming the drain plug is the pop-up type where you pull a small rod up behind the faucet, you can try the following:
In the cabinet below the sink you will see the rod come down that operates the sink drain plug. There is a horizontal rod connected to this that goes into the drain line with a small round cap. Unscrew this cap and pull the rod out. The drain plug should come up freely from the drain. After cleaning reinsert the drain plug and be sure the horizontal rod goes into the drain and through the hole at the bottom of the drain plug shaft. Seat the round ball from the horizontal shaft into the drain line and tighten the round cap to hold the horizontal rod in the drain.
Posted on Sep 17, 2010
What is the the bonnet nut?
Also known as a collar, it holds the faucet stem in place.
Jan 10, 2015 | Plumbing
How to remove bathroom single handle faucet ?
  1. Shut off the water supply
  2. Disconnect the supply lines
  3. Remove mounting hardware from underneath
  4. Pull the disconnected faucet assembly up and out of the sink
Jul 17, 2014 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
When i turn my bathroom faucet on i get a sewer smell for about 30 seconds then it goes away. its only in the bathroom at that faucet. what causes that? thank you
check under sink for a clogged or a bad trap in drain. it is hard to believe that the smell is coming from faucet.
Nov 03, 2009 | Home
Very low pressure when turn on the hot water faucet in sink
Shut off the water supply and open your faucets, and apply air pressure (min. 30psi) to dislodge any blockage in the pipes.
Oct 23, 2009 | Plumbing
Plumbing Logo
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
