Question about Casio G-Shock GW300CA-1V Wrist Watch
Can't remember where the little spring go in the g-shock 300
Replaced wathc battery and springs fell out can't remember where they go
  • 2,071 Answers
The used of the spring of your watch is for the speaker connection of the back cover of your watch. Your watch is still working even without the spring but no sound of alarm or whatever sound feature.Just go to watch service center im sure they have spear for the spring if not they can make spring from the watch spring bars.
Hope it may help you;
Regards;
VOTIT
DONT FORGET TO RATE;
Posted on Jan 26, 2009
Nike Triax Fury: when replacing battery, 2 springs fell out (silver and a gold one). Where do these go and where were they from?
I had the same problem - replaced the battery of my Nike Triax Fury and the time was blinking and none of the buttons were working. Turns out that you need both springs placed in the proper spot - the silver and gold springs. Both springs can be placed in their proper spot with the batter in. The gold one goes in the tiny hole near the "view" spot, and the silver spring goes year the 'cage' that holds the battery in place accross from the gold spring. Unfortunately, I can't add a photo or I would. Good luck.
Nov 29, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
Tip
LOST SOUND AFTER BATTERY REPLACEMENT.
If you experience no sound (alarm) from your watch after battery replacement, that means the coil spring fell out of watch while the battery has been replaced. Coil spring is transmitting vibrations from watch movement to the sound membrane at the back cover of watch, and if it is lost, there is no physical body to transmit signal, thus no sound. Coil spring itself is quite tiny and can be easily lost without even noticing it, mostly because it is not soldered to the watch movement or sound membrane and as soon as the opened watch is turned over, the coil spring fells out. If you are not able to find the coil spring in/around the place where the battery change took place, there is no other solution but to visit your nearest watch repair shop and ask to fit new one. In case if you are lucky enough to find the coil spring, fit it back in to appropriate hole in watch movement inserting out-bent end into movement. In most watches coil spring holes are marked: C.SPRING/COIL SPRING/ C.S or similar. Hope it helps.
on Mar 31, 2010 | Watches
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
Looking fo ra parts break down for the DW-9052 Casio. Was replacing the battery and the spring and a little metal tab fell out. trying to find out where they go.
if its a tiny little spring then those springs you will need to put them in a little hole on top of the movement so they press up against the back of the case when y ou put it on . I am not sure what metal tab you are referring to , but I am pretty sure it is the tab that goes on top of the battery and holds it down.
Oct 14, 2010 | Casio DW9052-1V Wrist Watch
I replaced the battery in the watch, programed the alarms , now the chime doesn't beep. how do i get that back?
As you are not watchmaker, you definitely lost coil spring, which is transmitting sound signal from watch's movement to the sound membrane. Coil spring is very tiny and this happens very often with people who do not know how the watch is built. No worries, though. Any nearest watch repair shop can fix it. Rate me, plz.
Mar 25, 2010 | Casio G-Shock G2900F1V Wrist Watch
Loose spring popped out from behind....now I have no sound!
this video will show you were the spring goes next to battery
Jun 14, 2017 | Casio G-shock G2300B-1V
Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
Jul 09, 2008 | Casio G-Shock G3110-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio Databank 150
If your databank is like mine (DB-35H), there is a TINY spring in a really unusual spot that you probably didn't notice that fell out. Laying the watch face down and with the back off, there is a little tiny hole in the back towards one of the corners. (sorry, already put my watch back together and didn't notice which corner.) There is a tiny (1/16" x 1/4") spring that sits upright in that hole. It must make a contact with the metal cover. I replaced my battery and when I did, a spring fell out. I looked all over the internet, then wrote Casio, who said they didn't have access to the information about where the spring went. (Doh!) I got a used DB-35H from my brother and was going to swap the innards when I noticed the spring on his. Put my spring back and it beeps! If you've lost the spring, don't know if you can fake it with tinfoil or not, but it really is a TINY spring. Good luck.
Mar 26, 2008 | Casio DBC1501 Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
709 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
