Question about Irons
ProSteam Plus 34'' Steam Press with Steam Burst - Lost Manual
Hi, I've got a ProSteam Plus 34'' with Steam Burst and have lost the manual; I wondered if anyone can help me to obtain a new one.
Many thanks
Fiona
Prosteam Plus 34 steam press- the cloth has wornout. where can i buy. QVC has no contact details
Posted on Jul 02, 2010
How to clean inside of iron
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's!
All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Sep 28, 2012 | Sunbeam 3017 Iron with Auto Shutoff
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
I need the instructions to clean the iron, please. I lost my manual. Thanks!
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Apr 02, 2011 | Sunbeam 4232 Iron with Auto Shutoff
STEAM FUNCTION STOPS WORKING
You need to replace the descaling resin. I have no idea where to find it, however.
Dec 06, 2009 | Irons
Lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards Ryno
Jun 20, 2009 | Singer CSP1 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Irons Logo
338 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
