Question about Acer Aspire 5100-5022 Notebook
Overheating issue - looking for service manual
My laptop has been insanely overheating for quite some time, even with the assistance of an additional cooling pad it still overheats. A while back I sent the laptop to Acer and asked them to repair this, which they told me would be no problem. It came back and they had fixed another issue, broken casing around the hinges of the screen, but hadn't fixed my fan. So I've decided I really need to do this myself, and started looking for the service manual for the 3020/5020 series. I found the 3000/3500/5000 one, but that series has easy access to the fan area, whereas the 3020/5020 series does not. Does anyone know where I can find the service manual for the 3020/5020 series without having to part with a few pounds? I'm sure it must be out there somewhere!
  • Chip1961 May 11, 2010
    I Have A Power Problem, And I Need The Service Repair Manual For An Acer aspire 5100
  • 624 Answers
Here is the service manual for the Acer Aspire 5100. Open this page, go down to the bottom and click on the link labled: "Download >>
Posted on Jul 16, 2007
    Guru:
  • 57 Answers
    Problem Solver:
  • 10 Answers
The fixing of the fan and/or the thermostat control is primary, I understand.
As a temporary fix or an alternative solution to bad thermostat units (or work that is just not worth the time or money) I have recommended cooling pads and they work beautifully!
I realize this is another part to manage and so forth but I also recommend these to my clients that have "hot" running laptops that can often be very hot to the lap.
If you need more assistance, please just ask!~
Posted on Sep 01, 2010
  • Alan Helmick
    Alan Helmick Sep 01, 2010
    P.S. If it is the thermal sensor, you are barking up a long tree. Make sure that they did not already replace the fan.
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
Guys I've got a problem with a ford bantam 1.6i 2003 model rocam engine, its overheating even though the cylinder head was skim but it still overheating. please assist!
Check what head gasket was used . I suspect that an after market gasket was used. If that is the case there will be holes in the block and head thet have no matching holes in the gasket thereby causing the problem
Jan 07, 2013 | 2006 Ford Bantam 1.6i
HP Pavilion dv2610us overheating causing laptop to slow down?Is this because my laptop battery died
Overheating is not caused by dead battery. The most common cause of it is a faulty system fan. If the fan has mechanical defect or has degraded performance due to accumulated dusts and particles around it, it will cause overheating. Overheating can cause system to slow down at first, then if you keep using it without minding the overheating problem, your laptop can freeze and shut down on its own.
Here are some tips for overheating issue:
- Use canned air to blow out dust and particles from the system fan.
- Do not operate the laptop in areas where the temperature is high, it will worsen the problem.
- Replace the fan if you notice that it is not working properly as before cause it will further damage the laptop.
Hope this helps.
Jul 09, 2011 | HP Pavilion dv2610us Notebook
When starting it is very slow, freezes often, and get blank page quite often.Thank for listening.
It may be an overheating issue, this is especially plausible if your your laptop is more than 6 months old, and if the internal fan spins a lot and is on almost all the time. Take a minute to read through this post for more detailed diagnostics and explanation of how to deal with overheating laptops. The post is for a HP6820, but the principle is the same for any laptop. There's even a mod for the chasis that will help you do the next cleanup in just 5 minutes.
Dec 21, 2010 | Dell Inspiron 1525 Notebook
I have a gateway AMD 9500 Quad core 2.20 Ghz 3.00
if it shuts down alot, its probably overheating due to cpu or graphics cards overheating.
check that coolers are not loose of clogged with dust, or even still running
Jul 15, 2010 | AMD Phenom X4 9750 Quad Core Processor...
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
Nov 17, 2009 | Computers & Internet
200E overheating and blowing fuses
can't afford the fee you charge. also, feel it is quite expensive since you don't even look at the machine. probably wouldn't use the service enough to make it worth the cost. info was on net without having to pay a fee.
Oct 27, 2009 | Bernina Sewing Machines
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
CPU Overheating
While I am not familiar with this exact model, (is it a laptop or desktop?), Overheating quite often is a symptom of not just needing a cleaning but of a fan failing, I wish I could tell you what exactly to do to open your unit up to clean it... When you do AVOID using any canned or compressed air on the cooling fans, as this will spin them up to speeds far faster than they are designed for, and if they are failing this can take them over the edge.
Apr 13, 2009 | Computers & Internet
I had the same problem. And i believe my method has the fix.
On the bottom side of the laptop, unscrew the door to access the CPU Fan....(closest to the power supply)
Make sure the system is OFF and not plugged in or no battery in.
You will see 2 tabs on the copper heat sync that holds it down to the cpu.
Unscrew both the visible tabs.
Bend Both Tabs upward to where when you screw it back down there will be resistance.
What that will do is secure the heatsync to the die of the CPU.
replace the CPU door, and start her up.
Hope this helps ya'll
Nov 26, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100-5022 Notebook Logo
1,471 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
