Question about Riccar Radiance Upright Vacuum Cleaner Bags
Reset filter clock - Riccar Radiance Upright Vacuum Cleaner Bags
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Nov 30, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Is there a filter to bissell pro heat pet ? PUMP
Check your User's Guide on page 13 for Maintenance and Care. There is a flow filter located under the flow indicator that should be cleaned after each use. To get to it you turn the Flow indicator cap counter-clock wise, lift the rotor out and the then the filter. Ensure you replace the filter with the stem in the up position. Reassemble in reverse.
Nov 21, 2015 | Bissell Vacuums
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I have an Accu-Time Electronic Clock Model #40240. Made in China, but have no idea how to set the time/date/ect. Is there a manual I can download?
It can't be done. The Accutime 40240 has a 3V lithium battery behind the 9V compartment that keeps the time should the clock lose AC power or even when the backup 9V dies. If however the 9V is removed, the AC power is disconnected and the lithium battery drains, there is no way for the end user to reset the time. There is a small data port in the 9V battery compartment which is how they initially set the time IMHO but good luck finding a way to do that outside the factory. Besides, these clocks are so cheap its probably less cost to get another clock rather than replace the batteries
Apr 04, 2011 | Vacuums
I have a digital alarm clock from Next - it has the followin gfeatures a mode button - none of the options include time or hour etc an alarm on/off button a button with plus at the top and minus at...
Hi Karen,
Sounds like a neat clock!
I can't find anything about this clock. Other projection clocks set the time change automatically. What happens when you try to push the + button. Does it set the time ahead?
Also, what does it do when you press "kight"?
Karen, if I can't help you with this, please post again to let someone else have a try.
Please write back and let me know what happens with these buttons.
Good luck,
Handie Andie
Mar 27, 2011 | Vacuums
I can't find the manual and need to reset the clock. Help!
We have no idea what product you're talking about. You've posted it in the "Vacuums" section of the site, but I can't imagine your vacuum has a clock unless it's one of the new Roomba robots with the timer on it. Post the question again, and include the exact part number of your vacuum.
Mar 23, 2011 | Vacuums
I am having problems setting the alarms on my Emerson Smart Set clock
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
Nov 03, 2010 | Vacuums
My Klik radio controlled clock did not reset from British Summer time to GMT last night. How do I fix it?
Had exactly the same problem. Moved the clock to another room where I guess the signal was stronger and it started to set the correct time in about 2 minutes. Voila!!
Oct 31, 2010 | Vacuums
Riccar Radiance Upright Vacuum Cleaner Bags Logo
22 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
