Question about Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 is not recognised by PC
We have this printer (never used) and when connecting to computer is not recognised as new hardware (nothing happen in fact). Drivers are up-to-date downloaded from web, connection are serial, parallel but either of them don't do anything.
Any suggestions what else to try?
Many Thanks
  • 19 Answers
This printer is not plug and play, you will need configure with the driver. If your driver is from Seagull, you have a option TOOLS, and it is possible to send a test.
Posted on Feb 10, 2009
Toshiba TEC B-472 Thermal Label Printer prints blank page first
Check in your software, you may have a alignement option checked or activated.
Jun 23, 2014 | Toshiba TEC B-472 Thermal Label Printer
Error sign shows On Error shows: SG;0015,0404,044after press restart shows: SG;0015.0036.048
If you are using a windows driver do not use Topix in the graphics.
Use 8 bits or 4 bits. The firmaware may not be able to understand the Topix algorithm. What you have is a syntax error displayed.
Feb 13, 2014 | Toshiba TEC B-472 Thermal Label Printer
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
I am not able to print to a local printer TEC 472 on LPT1. I get no error.
The B472 has a contronics SPP mode parallel
Check that you have the correct settings on your computer.
Besides take care the DB25 is a serial connection with
9600,n,8,1 setting by default
Jan 03, 2011 | Toshiba TEC B-472 Thermal Label Printer
Will not print
Change the chip on the main board. sometime this chips goes out. It's the only one mounted on a chip support
Mar 29, 2010 | Toshiba TEC B-472 Thermal Label Printer
All ok but not print
2 possibilities.
- The communication parameters are not correct
Try 9600 bds
8 data bits
1 stop bit (defaults)
Or the control character is not correct
See parameters
Jul 21, 2009 | Toshiba TEC B-472 Thermal Label Printer
TEC B 472 QQ
Swapping the parallel port to the printer should allow it to connect via parallel. Run through front panel diagnostics before/after install. depending on firmware it will tell you if the parallel board is installed.
Nov 09, 2008 | Toshiba TEC B-472 Thermal Label Printer
Tec 472 qq no print
I can only guess there must be a problem with a setting either within the printer or your pc. It's unlikely to be a hardware fault as the printer self tests ok.
I have repaired quite a few of these printers, but haven't had your problem. I can only suggest your compare the settings (baud rate etc)
May 19, 2008 | Toshiba TEC B-472 Thermal Label Printer
TEC 472 QP PRINTER
Try with CUPS --- oh, sorry, it's for Linux only, my bad
Jan 08, 2008 | Toshiba TEC B-472 Thermal Label Printer
Toshiba TEC B-472 Thermal Label Printer Logo
258 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
lancer284
Level 1 Expert
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
