Question about Magellan Road Mate GPS GPS Receiver
Magellan 1700 starts out bright then goes dim
When the Magellan 1700 first powers up, the screen is bright and then goes dim, hard to see in daylight. I have checked the "Bright" settings in the Menu and it is all the way up to the brightest setting.
5 Suggested Answers
SOURCE: Magellan Explorist 210
You want me tp pay to to fix my problem..And if i did fix it myself you want me to tell you so you can charge others??
Screw You!!!
Posted on Apr 03, 2008
  • 1111 Answers
SOURCE: When i start the Magellan maestro 4250 , the
try the hard reset. the little hole the size of a paper clip on the side of the unit. if that doesnt work, id say the digitizer(touch screen) might be broke.
Posted on Jun 12, 2009
  • 1111 Answers
SOURCE: switches on but goes directly to system settings - no way back
reset the unit (read your manual link below) if that doesnt work, the digitizer (touch screen) is probably broken.
http://www.magellangps.com/assets/manuals/mrm_1200_manual_en.pdf
Posted on Jun 15, 2009
  • 6 Answers
SOURCE: Magellan 1700 tried to do an update and afterwards
I found the same problem occured to me.'After the first download you have to disconnect the cable let the unit reboot and run for a few mins then reconnect for a further download. Had to do this twice and now my 1700 and my 1470 both work great.
Hope this helps
Posted on Dec 30, 2010
My Magellan roadmate 1700 doesn't open completely ,how can I fix it?
I had to send my 1700 back, contact magellan & see what they say
May 15, 2014 | Magellan RoadMate 800 GPS Receiver
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
How to make my screen stop dimming on a casio commado
Go to settings, Power Saving Mode, If the brightness is checked uncheck.
Mar 28, 2014 | Casio C771 G Zone Commando Verizon...
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
System.
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
Languages.
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
automatically.
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
Brightness.
3. Tap in the brightness slider to set the brightness of the display.
The
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
Magellan 1700 tried to do an update and afterwards all I get is the loading screen. The unit will not completely start up.
Hope this helps
Nov 11, 2010 | Magellan 1700 GPS Receiver
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
GPS Logo
100 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
