Netopia Motorola 2247-n8 Wireless Dsl Modem Wifi Gateway Logo
A
Anonymous Posted on Jan 19, 2013
Motorola netopia 2247-N8 vpn connection
Can't connect to company vpn with motorola netopia 2247-N8
5 Related Answers
A
Anonymous
  • Posted on May 29, 2008
SOURCE: Unlock netopia 2247 router
Well Netopia from eircom will sit on default username & password provided by eircom.
Only way you can use it with other provider is that you will need to update it with a new firmware from netopia's website !
spincycleus
Douglas Erikson
  • 62 Answers
  • Posted on May 01, 2009
SOURCE: VPN connection - Client cannot connect
Hi mwells960
Theres alot of differnet things i could ask you, but im going to assume you're jsut setting up a basic VPN. That means that somebody is telecommuting to work and wants to hit the server at work.
That means you have a static ip at work, and your at home workers has whatever, a internet connection lets say. Im thinking DSL with ATT since its a netopia 3347N.
If the netopia has a gui interface, you cant vpn thru it. Its not a VPN router. Its a residential router that you're trying to make do too much.
The sad news is, you can't upgrade it to an Enterprise having firmware router anymore, netopia use to offer that, but when Motorolla bought them out last year, they did away with that nice little feature. For true VPN'ing with a router, first, go get a VPN router to start with.
Most people accomplish what you are doing by putting the netopia in to bridegemode, and then putting a VPN router like a linksys behind it.
spin
Anonymous
  • Posted on Jul 15, 2009
SOURCE: Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Ekse
  • 13435 Answers
  • Posted on Nov 09, 2009
SOURCE: I have 2247 NWR-EIR wirelss modem. I have bought
Hi to confirm that the issue is with the wireless router, try connecting the xbox directly to your cable modem or adsl modem or similar so that its directly connected to the net.
if you still receive the MTU warning, then check and see if that is adjustable on the xbox itself and if its not, then that setting is most likely in the ADSL modem and not on the router. you would have to connect to the Modem setup pages and look for MTU there, it probably is there.
let me know if you need further assistance.
Anonymous
  • 68 Answers
  • Posted on Jan 10, 2010
SOURCE: i have recently updated to the netopia 2247-02
I would contact Motorola at http://www.netopia.com/support/hardware/2247w.html
They have a net chat option and an e-mail option that don't require you buy a contract. I did not see any way to access the downlevel firmware, but they should be told that their new firmware is causing issues.
I would do a complete factory reset before I did this and set up new configuration - just to be sure that it is not a cruft issue. By a lot of trouble, you mean having to try over and over again?
But this sounds like a technician issue and something that an owner needs to tell them about.
Testimonial: "thank you brasshopper, yes my a lot of trouble i do mean i try over and over again, i attempt to connect using my atheros wifi card, and no access. TY"
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Need CD for 2247-N8
You don't need the cd. Just go to http://192.168.1.254 to configure the modem. This is from http://www.motorola.com/web/Home/Products/Voice-and-Data-CPE/xDSL-Modems-IADS-and-Gateways/2247-N8_Netopia/_Documents/StaticFiles/Netopia_2247-N8=_User_Manual.PDF?pLibItem=1
Wont connect to internet on motorola netopia 2247-n8
Does it connect to the router or network? what happens when you open Internet Explorer? What kind of messages are you getting? Just saying won't connect to the internet could be a lot or reasons because getting a connection requires a number of things to be working.
Hi mwells960
spin
Vpn
this is not so much a soloution but an idea!
from memory the netopia devices allow you to configure a dmz device by IP or MAC address.
I have had to do something similar but with a buffalo unit instead of your linksys. I ended up having to place the buffalo unitin into a dmz created on the netopia unit. before VPN tunnles were formed correctly.
Patrick.
Top Netopia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
