XEROX PHASER 3140 ERROR
Not printing
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 141 Answers
SOURCE: Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Posted on Aug 04, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
jyackle5
  • 8197 Answers
SOURCE: Can't print with my Xerox
Code 016-720 means.
PCL print data contained a command that could not be processed. Check the
print data, and then try printing again.
Good Luck
Posted on Dec 07, 2010
SOURCE: Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer: Hello, I have a Xerox Phaser 3300MFP and there are...
Primero , apaga el sistema y desconecta la energia
Luego hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Oscar M
May 06, 2010 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
32 people viewed this question
jasbo
jasbo
