Question about Sansui HDLCD-1900 19 in. LCD Television
I have a Sansui HDLCD 1908B LCD TV, i just purchased a Samsung BD-E5400 Blu-ray Disc Player, There is no HDMI port on the TV just the AV plugs, how do i connect them together?
Coldcut
  • 1554 Answers
SOURCE: no audio for my 26" sansui hdlcd
use a cable box and external speakers they sound better anyway.
the circuit for your tv is not available yet.
Posted on Apr 26, 2008
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 49 Answers
SOURCE: how to connect a dvd player to a 19
Hi Is it not just a case of connecting a scart lead to the TV scart on the DVD, then into the Full Scart socket on the TV or have you done that and are having probs with it?
Posted on Dec 06, 2009
SOURCE: Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Posted on Dec 21, 2010
  • 10 Answers
SOURCE: I have a Sansui HDLCD 19WB. Can I add speakers?
Yes, you can either plug speakers into the back of the monitor in the orange colored slot. But in order for this to work, you must also plug the computer tower audio output into the Sansui's audio input port, which is located directly underneath the monitor's video input (where it is already connected to the computer). If that sounds like too much work, you could always just plug your computer speakers directly into the audio out of your computer tower.
Posted on Feb 28, 2011
How does one stream netflix via Blu Ray wired to ISP through a tv?
First you have to hook up network cable to Blue Ray player and to router
Next update software in Blue Ray player by going thru your menu in blue ray player to settings
If you have your blue ray player with Netflix app then all
you do is click on app and log in.
And make sure HDMI cable is plugged into TV.
And that should work for you. Any problems write me back.
May 04, 2014 | Samsung BD-E5400 - Blu-ray disc player
How do I connect my Samsung BD-E5400 blu ray player to tv and watch netflix with a wired internet connection?
From the modem to the blu-ray use an ETHERNET cable. From the blu-ray to TV use an HDMI cable. They only fit in the right terminals.
May 03, 2014 | Samsung BD-E5400 - Blu-ray disc player
How can I connect a samsung bdf5900 to my hitachi rear projection tv
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
Apr 30, 2014 | Samsung BD-F5900 Smart 3D Blu-ray Disc...
IS THERE A WAY TO HOOK ETHERNET TO A SHARP BR MODEL BD-HP20U
You can connect it by any way to your BDP. There are cables to connect in between. HDMI, S-Video & AV. After connecting these cables with your TV, select the appropriate selection to video by TV.
Jun 01, 2012 | Sharp AQUOS Blu-ray Disc Player
My samsung bd-p1500 blu-ray player won't play blu-ray discs on regular ones... was having all sorts of troubles with it finally updated the firmware and now it won't play any blu-ray discs
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Apr 01, 2010 | Samsung BD-P1500 Blu-Ray Player
No picture from Blu-ray
If the TV works fine with other sources the problem is the HDMI output is not enabled on the BD player.
Most BD players do not output both HDMI and composite formats simultaneously. Check to make sure the HDMI output is selected on the BD player and the TV. This information is in the manuals, read the book.
Cheers
Jan 15, 2010 | Hitachi 57F59 57" HDTV
No connection/ no signal
Either the new BlueRay player is defective, the HDMI port on the player is defective, or the port on your set is defective.
Try connecting it with component RGB/AV cables, or S-Video/AV cables and see if everything works. If so, then you know that it is either the port on the BlueRay, or the port on the TV set.
To test the HDMI port on your TV, you will need another HDMI device to try.
Jerry G.
Aug 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
When hdmi cable is plugged in bluray player stops
Since it was stretched check the ontacts on the acutal HDMI connector on the tv and the bd player a pin bent or touching another pin will cause a vast amount of issues
Mar 29, 2008 | Samsung BD-P1200 Blu-Ray Disc Player
Sansui HDLCD-1900 19 in. LCD Television Logo
50 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
