Canon GP605 Error E220 - Office Equipment & Supplies
Canon ir600 error code E220
sira canon 600 mechan E220 has cmming turn of the power has coming solve the problam how to slove the problam slove it
Jul 17, 2012 | Canon ImageRunner IR600 Copier
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
We have a copier CANON IR 400 and shows the message E220
This is the Charge Coupled Device. Its a part that would need to be replaced by a technician. There is no way to explain to you how to get to it or how you could order this part. Your local canon dealer should be able to help with this problem.
May 10, 2010 | Canon imageRUNNER 2270 Copier
My cannon ir400 eror e220
this error is related to exposure lamp , does the the two end of the lamp is blackened. Otherwise the exposure lamp needs replacement
Jul 20, 2009 | Canon imageRUNNER 2270 Copier
Error code
the inlet motor m1 is faulty
Jun 09, 2009 | Canon Office Equipment & Supplies
Canon np1530 copier e220 error message problem, how can solve this problem?
E220 is a scanner error. means:
the exposure lamp is burnt.
try copying with the top cover open, if the lamp does npt work, exchange it.
Good Luck.
Mar 12, 2009 | Office Equipment & Supplies
Error e014 on canon gp 605
I THINK E014 IS FUSER UNIT MOTOR.REPLACE MOTOR.DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Feb 22, 2009 | Office Equipment & Supplies
CANON 6050 B TO B ERROR
The gear on back side of b to b tray got lot of lubricaion. it was removed by alcohol. gear slipping was the cause for it
Sep 26, 2008 | Canon imageRUNNER 400S Copier
jasbo
jasbo
