Question about RCA D61W20 61" Rear Projection Television
Burnt spot on board
I have a burnt spot on board by flyback is there any way to fix it?
    Sergeant:
  • 227 Answers
Depending on what caused the burn spot. It is possible to solder a bridge or jump wire from the point on the board that is not damaged and follow the trace or film connection to the next point that is to connect the two points. Other wise find a solder point on one side of the burn and if you can follow the path to the next solder point, use a jumper wire and solder each connection bridging over the burn. Wire has to be insulated. Some burn spots are caused by poor factory dipping of the board, and the solder loses connection over time from heat etc.
Posted on Jan 26, 2009
Funai magnavox model#37md359b-7 when turned on for amp fuse blows on circuit board
Could be 100 things. Do you see any burnt components or burnt spots on the board? Probably no way for you to fix this unless you have the electronics repair skills unless you visually spot a short on the board like a loose screw that ended up laying on a couple of components etc.
Feb 18, 2013 | Funai Magnavox 19" Class 720p 60hz LED TV...
I have a RCA d52w20 that's giving me a 3d affect
The part if near the flyback will kill the convergence adjustment being seen in the menu.
Set has issues (three similar parts) for bad solder connections at the flyback and a kit is available for the protect part (includes that part and a filter cap and diode with instructions-----------
Not a easy set to work on in many ways............
May 20, 2012 | RCA Televison & Video
Smells like it is burning when plugged in to the outlet
either the flyback or the CL031 box capacitor in front of the flyback has burnt a hole through the deflection board.
Aug 18, 2010 | RCA HD52W59 HDTV Projection Television
On what board is the convergence fuse on a ITC222. Have the Convergence Power Supply board out and cannot spot it.
The fuse for the convergance power supply most likly is not your problem, go to the board below it, the deflection board and neer the flyback you will find three small fuses the one in the center is the most common problem with convergance and this also can be cused by the pins for the flyback comming unsoldered
Nov 10, 2009 | RCA HD52W59 HDTV Projection Television
Our GE Arctica PSS27NHN has gone out. We took a look inside and found the motherboard has a burnt spot, so that is most likely our problem. Can anyone tell me if this model is on the recall list. I have...
No recall list that I know of .G E now has 2 boards available . The pt# you need is WR55X10656 . Less problems than a board for each model .
Jul 19, 2009 | Refrigerators
Turn tv on all it does is clicks but doesnt turn on
This sounds like your flyback unit on your main board is burnt out! this is a commen problem and the part is in the 70.00 range!
This should fix ya!
Dec 12, 2008 | RCA P46924 46" Rear Projection Television
Turn off by it,s self
Just took a look at one of these, and its cold soldering joints on the main board. I re-soldered all the solder joints around the flyback transformer and a few other suspicious looking spots (didn't note where those spots were). Took maybe about 30-45 minutes and now the set is running great. This would cost you about 70-100 dollars at a TV repair shop. No parts required unless the protection circuits didn't kick in and burned out a component someplace.
Nov 22, 2008 | Disney DTD1363-CAR 13" TV/DVD
Part?
Go to Tritronics or Union or Andrews electronics for RCA parts. They all have websites.
Jun 08, 2008 | RCA HD52W59 HDTV Projection Television
Toshiba theaterview tz50v51
my guess would be flyback however your lucky you might be able to see a burnt spot on the board giving you a better clue.
Nov 25, 2007 | Toshiba 55H70 55" Rear Projection...
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
