Question about Razor MX650 Electric DirtBike
Razor mx 650 wont hold charge
New batteries installed,seems to die almost instantly after charging
5 Suggested Answers
  • 850 Answers
SOURCE: e-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
Posted on Jul 18, 2009
SOURCE: On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Posted on Jul 19, 2009
  • 38 Answers
SOURCE: My sons razor e200 dies quickly. I have changed
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Posted on Aug 18, 2010
  • 319 Answers
SOURCE: Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Posted on Jan 04, 2013
How long does it take to fully charge the battery for a 2003 yamaha 650 v star classic?
check to make sure the battery is charging when bike is running or maybe a battery draw
Sep 14, 2014 | Motorcycles
Low battery backup
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jun 08, 2012 | Razor MX350 DIRT ROCKET - BLUE
What's your problem?I
Batteries for your shaver are 1.2V. If you have instaled it properly with good solder connections it sounds like there may be a problem with the board
Nov 10, 2011 | Health & Beauty
Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Apr 02, 2010 | Razor MX500 Dirt Rocket
Battery charge
you need to change your razors battery.
Mar 23, 2010 | Panasonic ES 8093 Electric Shaver
Razor MX 650 wont run
i had the same problem but fixed it this morning, i just sat far back on the seat when turning throtle with all my weight and then slid back on normal when moving, but it makes a grinding noise.
Jul 23, 2009 | Electric Razor Pocket Rocket Ride-on...
My 1997 650 savage wont keep a charge
Hmm, do you have a voltmeter, check the voltage on the battery with it running, usually 13.5 to 15 volts
If that reads ok, you probably have a short, get a testlight, pull off the negative cable off the battery,clamp one end to the cable and the other to the battery. If it lights up, you have a short, start unplugging stuff until you find the short and the light goes out!
Jun 09, 2009 | 1989 Suzuki LS 650 Savage
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Volvo 240 wont hold charge
if with the volt meter the amps go down while running and at increased rpms than your alternator is not charging right
Mar 11, 2009 | 1989 Volvo 240
Razor MX650 Electric DirtBike Logo
62 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
