Question about Olympus Camedia Cameras
E10n does not turn on
Unit will not power on
    Genius:
  • 1,019 Answers
If it is not a battery problem the camera needs to go to the shop.
Posted on Jan 26, 2013
"H'i I have Furuno 663 Echo sounder in my boat and when i switch the main aux power on the sounder comes on automatic and then i can turn it off and on all day
A trick that I have found with the marine Furuno products is that they remember the state that they were in the last time power was removed from them.
In the unit is off when you remove the AUX power than when the AUX power is turned back on the unit will remain off.
If the unit was on when the AUX power was turned off then the unit will be automatically turn on when power AUX is turned back on
This feature keeps the unit alive if power is disrupted under way so that the helmsmen doesn't have to keep turning it back on during busy times.
Dec 09, 2015 | Furuno GPS
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
Red light comes on but the unit wount turn on
The red light is associated with the memory (constant 12 volt power). You also need switched 12 volt power (power with key turned to accessory)for the unit to turn on. If you installed the system yourself, you are looking for 12 volts on the red wire of the Jensen unit. If power exists at the unit, check the fuse of the unit and the fuse of the vehcile.
Feb 03, 2011 | Jensen Vm9214 Car Video Player
How to fix a black screen on a laptop
There could be one or more problems with your notebook, a black screen could be a system board problem. Does the power light come on? If so turn unit off and unplug it, remove the battery and plug the power supply into the unit. Turn unit on. If the unit turns on it is a battery problem. If it doesn't power on then turn unit off and reinstall the battery and turn the unit, if you unit has a vga port on the side hook a monitor up to it and see if you get output. If you don't it is probably a system board problem.
Nov 08, 2010 | Computers & Internet
Can the lg dvd rewriter gsa-e10n be used as an external info store as well? if so how many gb? thank you!
No dear. External Hard disks, pendrives etc does it for you. A CD/DVDRW plays only CDs & DVDs + burns CDs & DVDs. Please send me your feedback & vote to motivate us & to help us help you.
Feb 12, 2010 | Computers & Internet
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Reset power
To do partial Reset.
1.Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit.
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Media Center Power Up Problem
replace the power supply-from a computer store, should be no more than 30 dollars
Nov 02, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Cameras Logo
14 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
