Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
PCI Slot not detect any device
When I install wireless NIC card in PCI Slot it is not work
    Scholar:
  • 145 Answers
Please post questions in detail to help us to serve you better. The answer which I'll be providing you is based on assumption on the little data you have provided. I think you haven't loaded the driver for the said card and hence, your PC is unable to detect the card. The drivers are usually supplied with the card on a disc,Just run the disc and if should solve your problem.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Jan 26, 2009
Compaq Presario 5220 Desktop Windows 98 internet: Dial-up Can a DSL card be installed or would I need to go with a wireless USB? And would wireless USB work on Win98?
You can install a network card inside the computer. You will need a PCI or an ISA card. (I know PCI network cards are easy to find at most of the computer shops.) See this site for how to install a card: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07111&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=93139 . However you should open your computer and check the space between the devices in the slots in the computer. There is an AGP slot with a video graphics card, 1 PCI/ISA slot with a modem (default specs), one free ISA slot and one free PCI slot. However depending on the graphics card one of these slots may be blocked by the card. You'll either need to get a card that fits the available slot or remove the modem and use that slot.
Here are some PCI 10/100 network cards: http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=587&name=10-100%20Ethernet%20PCI/ISA . Most of these are compatible with Win98. I'm not sure if there are any gigabit NIC with Win98 drivers.
Wired and wireless USB NIC adapters exist. However, you will be limited to the USB speed. If you have USB 1.1, that will be really slow. Most likely your computer will require a reboot anytime the connection is lost.
I hope this helps.
(who recently removed an internal modem to put in a PCI gigabit card in a newer desktop than yours. The procedure was straightforward and improved network performance in the household immensely. The failing on-board NIC was tying up the router for everyone.)
May 12, 2011 | Compaq Presario 5220 (388098-003) PC...
Greetings, I am a technician. However, I ran into a confusing issue with my wi-fi. My Encore enlwi-g v2 PCI wireless adapter worked fine on my Windows 7 64-bit system until I bought a new Smilodon case...
Mike, your problem is so clear and crisp... Thank you for the excellent documentation...
Here is the solution...
The wireless PCI card should be detected by any PCI slots, doesnt matter whatever may be the chipset made off...
The Light in the adapter is "OFF", says there is no power supply to the adapter and that is the reason the Wireless card is not detected...
unplug the adapter from the board and clean the PCI slot on board with a soft brush(the Pins in the PCI slot may get in contact with each other if u use any hard materials to clean)...
On the PCI wireless card clean the metallic contact surface (the place where the pci slot comes in contact with) using an ERASER and clean the dusts left by the eraser properly...
Now connect it back and check if the light is getting LIT up on the card...
Then you can also check under device manager either in Network adapters or under other devices...
Sincerely, Manny...
Dec 09, 2010 | Encore (ENLWI-G) (ENLWIG) 802.11g/b...
How easy is it to install a Network Interface Card into a Dell Dimension 4300? Any advice on what make/spec of card to buy?
If your PC has USB jacks, you can install a your choice of either wired or wireless network interface cards without as much as touching any tools (except for maybe a razor knife to open the package). If opening the case is something you're not comfortable doing, this may be the easiest way to get network connectivity.
Installing cards is not that difficult, but you need to open the case and determine if there is an open slot available and which type of slot it is. Most modern PCs have PCI slots and a PCI express (or older AGP video card slots). Again, not too hard figure out which type you've got.. search for pictures of slots on google. Look for PCI AGP PCIe and ISA slots so that you might compare them with those inside your PC to determine which type NIC you'll need. Then, buy a NIC that matches the slot and install as per directions.
I hope this was helpful & good luck!
Mar 12, 2010 | Dell Dimension 4300 PC Desktop
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Installing NIC card to dell optiplex gx100
NICs usually come in PCI interfaces. motherboards have usually four PCI slots to hold many devices such as NIC. just slide the card and fit it into the PCI slot. It could take any of the slots where it fits. the OS will detect it and loads the necessary drivers.
Aug 28, 2009 | Dell Ethernet Card Network Adapter
Rtl8168/8111 pci-e lan failing
hi
i think the issue is more to HW than SW
just a thought but, place the ethernet card in the slot properly but donot put in the screw to attach it to the cabinet and check to see if the card is getting detected
also try checking if te card works on some other machine with either XP or some other
just a hunch though
cheers
pls rate if it was any help
Jul 03, 2009 | Computers & Internet
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Need to download software for gn-788v pci driver ethernet card, a drive not working, need it off the web?
Hello there.
Please navigate to http://sonic.net/support/nic_drivers/ and choose "Genica" , from here you can download the driver files needed to install the network device. There should be 3 files, if you download all these files and then in windows point the hardwarea detection wizard to the location you saved the downloaded files. It will then install the device.
Hope this helps.
Apr 06, 2008 | Genica GN-788V 10/100 PCI Network...
Doesn't install properly on Thinkpad 760XL running WIN98 SE
Make sure you have all the drivers handy.
Uninstall the sound
Uninstall the modem
Uninstall the nic drivers as well as the wirelss nic drivers.
Uninstall all others that have conflicts.
Remove the adapters out of the pcmcia slots. (Ethernet, etc
Shut down and restart the system.
The system should detect all hardware again.
Now if this laptop has an onboard nic and modem disabled them
Shut down and restart system.
Check control panel to make sure they are diabled.
Now istall the combo card nic/modem.
If this does not work you should try diabling them in the bios.
As for the wireless nic. You normally would have to install the software prior to inserting the adapter.
Let me know what happens
Hope this helps you
Nov 02, 2007 | IBM EtherJet Network Adapter
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
