Question about Candy AQ130 Front Load Washer
Sticks half way thro programme
I have a activa smart candy washing machine, and will goes as far down to 27 on count down and stops. it wont drain or do anything else. it just says on screen 27 and count down light is on.
can you help me please
Found the problem,unplug machine pull out remove back cover screws look in side machine,there is a black pipe on right hand side bottom of machine,that is the drain pipe to the pump,remove jublie clips and check for blockages,mine was blocked refit cover and put machine on normal cycle to clean,
machine works fine now,
Posted on Jan 27, 2009
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
In my candy activa smart 12 the powder and conditioner are not getting a flow of water through yet the water is entering the machine and the wash cycles working
candy activa smart 12 the powder and conditioner are not getting a flow of water through This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 13, 2011 | Washing Machines
I have a candy CMI 146 ACTIVA SYSTEM washing machine it stops half way through a cycle. The water does not drain away and the door security light comes on and the door does not open.
  • You probably have a blockage in the drain outlet. heck the outlet trap and then the hose from the bowl to the pump
  • Often coins get in this hose.
  • Goog luck
  • http://www.appliances.cjb.net
Jan 22, 2011 | Washing Machines
My Candy C514 Washing Machine stops half way through the cycle and lights flashing.Yesterday mechanic came and checked everything ok Motor, pump and water goes in fine, any idea? What this can be? Many...
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Jan 19, 2011 | Candy Washing Machines
Washing machine tripped main fuse breaker, now won't work
Yes. It may be an internal safety fuse or switch. RJ
Sep 29, 2017 | Candy Washing Machines
My washing machine wont drain water
if waser wont drain it cant spin and some contorl boards get confused about that situation.check your pump,is it clear will it funktion.other wise i dont know a lot about this proticular machine god bless,tom
Jan 01, 2009 | Candy Washing Machines
Candy Activa Smart 1300 AA
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 25, 2008 | Candy AQ130 Front Load Washer
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Candy AQ130 Front Load Washer Logo
421 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
