Question about Dual XDVD8181 Car Video Player
HOW TO BYPASS PARKING WIRE FOR XDVD8183
HOW DO I BYPASS THE PARKING WIRE FOR A XDVD8183
    Scholar:
  • 116 Answers
Unfortunately the Duals on't work like the Jensens do. I know of only one way. Get it to bypass with a toggle switch and go through the sequence to get it to come on. You may want to wire it hot all the time so you don't have to do switch flipping every time. Trust me it's a pain in the booty. Once bypassed, since the deck is on all the time, you manuall shut it off thus retaining the bypass.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Is there anyway i can bypass the e brake on the dual xdvdn9131 so my kids can watch t.v on road trips
Ground the parking brake wire and put an on/off switch between the head unit and the ground. You have to have a switch on this model because you must apply the the brake, disengage, then apply again for the video to begin working. Make sure your audio is good quality, because if you play the XDVDN9131 with the volume up too long the unit will over heat.
Sep 17, 2010 | Dual Electronics XDVD8183 Car DVD Player
Clarion nx700 parking break bypass
Wrong. To bypass the lockout feature so you can see the DVD play anytime - you need to toggle the green wire away from ground (from Low to High - i.e. momentary switch) so the radio sees the rising edge of the 12Vdc signal. The green wire is normally high and is tied low. When you put the parking break on - it opens the loop.
A switch will trigger the Opto Isolator inside the head and bypass the lock out feature. This works fine - or you can spend the $25 on the bypass module - that does the same thing - but works as an electronic toggle ~ based off the remote wire and an internal relay in the module. The module will toggle the green wire every time the radio powers up.
Jul 01, 2010 | Clarion NX700 Car Video Player
On a Dual XDVD8183 how do i bypass the parking brake? I never found a clear answer.
You just have to ground out the wire that you are supposed to connect to the parking break, so you can do it by just attaching it to the frame through soldering or the cheap way which would be to just screw it in the with mounting screws either way works
Mar 25, 2009 | Jensen VM9510 Car DVD Player
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
BYPASS
The security device was created to avoid you from watching DVD's while driving. It is simple to bypass. Simply take the parking brake wire (blue/yellow stripe wire) and connect it to the a ground wire (all black wire). This will trick the DVD player into thinking that the car is in park with the parking brake on at all times.
Apr 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Dual XDVD8181 Car Video Player Logo
274 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
