Question about Durabrand Portable DVD
Battery charger Need battery charger model no Chrr-2
2 Suggested Answers
  • 303 Answers
SOURCE: NEED BATTERY CHARGER
click on hyperlink
buy replacement ac power adapter Durabrand PDV-709 tad10 tad-10 charger
Posted on Feb 12, 2009
Hello I need the 14 volt 1000ma barrel-end charger for the Kalee Fire Truck. 40029 I can't get it anywhere
One of these. Here you go
Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery ...
https://www.saretailinc.com > RideOn and Toys > Replacement Parts Best price for Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery Charger (Barrel End)
Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys ...
https://www.amazon.com/Kalee-1000mA-Battery-Charger-Barrel/dp/B016V5Q1EG Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys & Games.
Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma ...
www.bestscooterbuysstore.com/kalee-14-volt-battery-charger-2-prong-12-volt/ Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma Charger (Labeled 14v Charger) ... Kalee 12v 1000ma Charger (Labeled 14v Charger). This item usually ships ... Mini Motos 12 Volt Barrel-End Charger $31.99. Kalee 6v ...
Oct 23, 2017 | Cars & Trucks
I just bought a Digipower model TC-U450 and am trying to charge a Nikon EN-EL20. My battery has 4 contact points but there are only 2 prongs on the charger. How do I charge my battery with this charger?
The battery has 4 contact points, but there are only 2 that are charge points. The + (pos) and - (neg) are the ones you need to adjust the charger contact points to make connection with.
Dec 25, 2014 | Cameras
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
I am looking to buy 2 new batteries for my power pro clippers model 48951-005, where can I buy them?
I too need the same batteries but Oster stopped making them and now if you want a battery to fit the female part of you set you need to buy a new battery with a new gizmo at the price of over $150 Making what you have worthless and making what you need cost more than two old batteries or a new machine all together. Its a real rip-off.
Sep 18, 2012 | Oster POWER PRO Cordless Clipper 76600-013
The battery is flashing red when charging
You do not mention which model of Motorola radio you are charging, so this will be basic information: Typically if a charger blinks red when the battery is initially put on the charger, you either have:
1) Dirt contacts. Solution: Clean with pencil eraser, both radio and charger contacts.
2) Shorted or bad battery. Solution: Replace the battery.
3) A bad charger. Replace charger.
Some simple troubleshooting might determine your problem. Try the battery on a different charger and see if you get the same blinking light. If so, you have a battery issue. If the problem disappears when you place it on the known good charger, then you know you have a charger issue.
Best regards.
May 17, 2011 | Motorola Walkie Talkie 2-Way Radio
Need battery charger for robust 18v drill/driver. charger model 9706
need battery charger for robust 18v drill/driver. charger model 9706
I have exactly the same charger with the battery .
my drill is fallen , and it is broken .
Jul 13, 2010 | Drills
How do you recharge the battery on the power shot sd 1100?
A quick look on Cnet reviews says the specs for battery and power are:
Power
  • Power Device Battery charger - External
Battery
  • Supported Battery Canon NB-4L
  • Supported Battery 1 x Canon NB-4L Li-ion rechargeable battery ( Included )
An NB-4L battery charger is what you need to charge the battery for that model. My Canon charger is a small box with fold out wall socket prongs and a mount for my battery to slip into.
This looks like a Generic version sold on eBay, that includs a Euro/mexico Socket adapter.
Dec 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
I need the schematic diagram for a sears battery charger model 608-718330.
sears battery charger 50 15 2 works but wont charge battery what might need to be replaced chad 10
Aug 12, 2009 | Measuring Tools & Sensors
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Durabrand Portable DVD Logo
62 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
