Question about Dryers
Bosch exxcel vented dryer ,filter light keeps coming on?
Tried cleaning under lint collector,also at the back where pipe is connected.light keeps coming on and stopping machine
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Posted on Mar 30, 2009
svicari124
  • 21 Answers
SOURCE: I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Posted on Sep 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
How to respond to "Clean Lint filter" light.
had similar trouble and it can start a FIRE. Try cleaning the vent outside. The shutter doors can be hindered by lint and critters. If cleaning the vent door is not enough, take vent pipes apart and clean them. This should be smooth aluminum pipe not, the corrugated plastic etc.. If this does not cure it, the blower may be clogged or dead inside your machine.
Mar 05, 2018 | Kenmore Dryers
My bosch gas dryer has a E01 code,would like to known what that is.
It could be a venting problem. Check the lint filter and the vent pipe to make sure they are not clogged with lint. I have heard that greased lighting works well for cleaning the fine lint filter. Also check where the pipe vents and make sure it is clear. Sometimes vent caps have the mesh screens left on them. When cap vents are used the small mesh screen should be removed so any lint that blows through can clear the venting system. I hope this helps. Link for cleaner: http://www.greased-lightning.com/
Apr 21, 2011 | Bosch Dryers
It over heats and turns off but clothes still damp
You might consider checking to make sure your vent pipe and lint filter are clear if you have not already done so. These dryers are prone to lint build up where the lint filter is inserted and can this can impact drying. You can also remove the vent pipe where it connects to the dryer and see if it works better. If it does your vent pipe may need to be cleaned. Let me know if the suggestions help. .
Feb 06, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
WTV74307GB
the warning does not strictly mean filter only
there is a lint blockage somewhere in the vent system and there is only a single response the dryer knows to make
fan
fan housing
duct
outside vent
could all be sufficiently blocked to set off the warning
Oct 19, 2008 | Dryers
WTV74307GB
take the lint screen out and clean it with a toothbrush and warm soapy water. You may be using too much softner. If that doesnt work, the control board may be bad.
Mar 30, 2008 | LG DLE2514 Electric Dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Dryers Logo
572 people viewed this question
Top Dryers Experts
