Question about Plumbing
Kohler k-p15700-k leaks - Plumbing
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: FortĀ® Single-control...
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
How do you repair a leaky centerset Kohler forte fauset
That faucet has a lifetime warranty. Call Kohler (1-800-4-Kohler) and tell them you need a new cartridge for a K-10270 faucet.
May 01, 2014 | Kohler Forte Two Handle Centerset Lavatory...
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
How do I replace a cartridge for kohler bancroft sink faucet?
kohler bancroft is the sink manufacturer, not the faucet mfgr. do you have a clue what faucet mfgr it might be?
Jan 14, 2018 | Kohler K-10577-4-SN Bancroft Widespread...
Kohler K-34-39 leaks
Hi James
You need to replace the rubber gasket between the tank and the bow, that is where yoiur tank is leaking from..
Be sure to use a level when tightening down on the screws to keep the tank level
Bud
Apr 20, 2013 | KOHLER Memoirs elongated toilet with...
I have a Kohler Fairfax 12176 kitchen faucet and it is about 4 years old. It is starting to leak water out of the spout for a split second on occasion when you turn the water on. As time goes on, it is...
Kohler K-79402-CP aerator kit
Kohler K-78250
Kohler 1001100
You might try to replace aerator on end of spout if water is leaking around it, or you might try to replace cartridge. VALVE (CORALAIS AND FAIRFAX)
K-GP77548
$14.80 List Price
Call Kohler if you need more info.
Dec 16, 2017 | Kohler K-12176-PB Fairfax Single Handle...
I have the Kohler model 703 one piece toilet. It runs once about every ten minutes. It sounds just like a flush but nothing happens in the bowl. Any ideas?
Something is leaking. Your description sounds like tank water is slowly leaking and then the tank refills. You really need to use Kohler brand parts, as others pieces seem to not work well.
Sep 20, 2010 | Kohler Toilet - One Piece with Ingenium...
Plumbing Logo
191 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
