Question about Wahl Health & Beauty
Wahl beard trimmer model 5537n fix the blade
How to put the blade back together
  • 61 Answers
SOURCE: I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Posted on Jan 26, 2009
SOURCE: re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
Posted on Aug 26, 2009
rick_stokes_
  • 61 Answers
SOURCE: How to attach beard regulator on Wahl Groomsman
The attachment should hook over the teeth of the blades and then snap onto the back end.
Posted on Sep 27, 2009
brector3
  • 1610 Answers
SOURCE: I lost my instruction manual. How do you oil the
Oiling the trimmer is very simple. It is only necessary to apply oil to the blades. Simply apply one or two drops of oil directly to the blades while running. This should be done before each use.
You should have gotten a bottle of the blade oil with your clipper. If you have also lost this, you can buy a bottle of Wahl clipper oil from shaveroutlet.com. see link below
http://shaveroutlet.com/wahl-4oz-squeeze-bottle-clipper-oil-p-584.html
Posted on Jan 24, 2010
SOURCE: Have Oster model 23-51f fast feed trimmer. Took
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Posted on Feb 01, 2011
Wahl beard trimmer 9918 pulls after opening to remove debris.
may not be put together exactly right. take apart again and clean with a brush make sure every little piece of hair is removed, apply a little oil between the blades and try again.
Oct 14, 2017 | Wahl Health & Beauty
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
How do i put back the blades on a wahl 9918C beard trimmer
You connect the blades together with the plastic part the correct way through the top of the small moving blade. The plastic part becomes a guide to keep the 2 blades running straight and true. Then engage the plastic part into the motor cam shaft and the 2 tension springs at the same time and wriggle it onto the screw hole posts and fit & tighten the screws. Lubricate and you're done.
Jun 22, 2014 | Wahl 9918-600 Beard Trimmer
I took off the head of the wahl clipper model # 5537n and now i cant put it back
I fixed mine same model what you do is take the big blade lay it on its backside all the increases face up and take the black pieace attach it so the bottom part with the open hole is face down allign inside and place this on the creases with blades backside together then hold against clippers attach screws and wolla
Jan 15, 2012 | Health & Beauty
HOW DO I PUT MY WAHL HAIR TRIMMER BLADES BACK TOGETHER
well the smaller blade sits on plastic piece that is coming out of the clipper, having the inside of blade towards you. then larger blade ,the inside of that faces smaller blade,and align them to where you can see smaller teeth thru larger ones put screw back in and tighten. then oil them.
Nov 10, 2011 | Wahl 9854400 Hair Trimmer
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
On a Wahl Beard Trimmer 9876-536 -- what's the button on the side of the trimmer for?
The button info requested is almost 2 years old, but on my trimmer the button to the left of the power swt on the side is to lock the trimmer blade in the front or rear position. It is kinda weak and you can still move the blade if you push it. (I do seem to have the same one shown in the picture here.)
Later!
The Shadow
Nov 17, 2010 | Wahl 9876-500 Beard Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Health & Beauty Logo
97 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
