Question about RIM BlackBerry Storm 9530 Smartphone
Blackberry Storm Pairing code to landrover
I have contiually tried land rover pairing code 2121 which blackberry refuses to connect ??
  • Anonymous Mar 20, 2009
    I have tried to pair my storm with my laptop I have entered the paring code 0000 but it is not working.
    Sniper:
  • 92 Answers
The blackberry default code is 0000 have you tried this?
Posted on Jan 27, 2009
Why every time i get inside i need to pair my phone on range rover
In most car stereo systems, there is a wire that gets constant voltage to keep the memory settings and it should be fused. I would check it to see of the fuse for that line is gone. Does the radio remember your preset stations? If it does, then I am wrong. Sorry!
Mar 19, 2014 | 2006 Land Rover Range Rover Sport
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
How to pair blackberry storm to plantronics explorer 232
I am a little rusty on the PLantronics 232. but I believe to put it in pair mode, you have to press the volume up and the MFB (multi function button= button that answers and disconnects calls) at the same time. then pair your blackberry like normal. as I recal the pair code either 0000 of 9876
Feb 14, 2010 | RIM BlackBerry Storm 9530 Smartphone
Blackberry storm won't accept 0000 as the passkey, in pairing mode
Not all headsets use 0000 as the passkey for pairing mode. Check you manual and make sure that the device your attaching to the blackberry does. If it does, make sure that it has not already been paired with something else.
Jan 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
What is the pairing coad for the blackberry storm%3F
If you're referring to the bluetooth code, the default code is 0000 (four zeros). Good luck
Oct 16, 2009 | RIM BlackBerry Storm 9530 Smartphone
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Paired Blackberry Curve 8310 w/Range Rover 2005 drops calls
Ok, this isn't so much a solution as a work around.
As long as your phone is still holding the call (showing connected), once the Range Rover drops the call, hit the soft button that shows a picture of a green phone receiver....as if you were making a call. This will cause the Range Rover to reconnect the speakrs/mike to the phone, and you can continue your call in relative harmony.
I still haven't figured out how to get out of the jam when a second call comes in while you are still on the first....
Good Luck
prduck
Dec 10, 2008 | 2005 Land Rover Range Rover
RIM BlackBerry Storm 9530 Smartphone Logo
469 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
