Question about Dometic RM2652 Refrigerator
Freezer working on gas but not fridge compartment.
My dometic 3way fridge is only 18 mths. old and running on gas is not cooling the fridge section at all but the freezer section is ok.
If I turn it over to electric it is working ok.
The flame seems to be ok.but runs very hot out of the fleu,hotter than electric.
I have had a lot of problems with the Marshall twin stage regulator,so much so to change it to another twin stage regulator-Cavagna Group 524A.
The fridge has been running on the new regulator for about six trips away with no problem.
The fridge is fitted in a A Van Aliner Camper and I have no problems with the fridge till now.......Please hope you might be able to help me with this problem. Regards Ian Savage.
  • ianandfaysav Jan 30, 2009
    Problem seems to be the regulator, again!
    Have replaced regulator and fitted copper pig tails to the gas bottle.
    So Far So Good!
    Habit-Forming:
  • 60 Answers
Check to see if you have the right gas pressure at the refer
Posted on Jun 05, 2009
  • 4stevetaylor Jul 25, 2009
    ckeck if the gas jet is clean
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
The freezer compartment is working fine, holding at -18 degrees but the fridge section will not chill and has been holding at about 14-15 degrees for over a week but does not get any cooler than...
It sounds like one or more of your cooling tubes is blocked. Either you have a ice or frost buildup on your freezer side or something else is blocking it.
I would suggest you take a look behind the panel in your freezer and use a hair dryer or heat gun to blow warm air down the cooling tubes.
Jun 26, 2011 | Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Samsung side by side
Check for snow on the back wall of the freezer compartment, Air to cool the refrigerator is supplied from the freezer section. If the coil is frozen over the air circulation becomes retarded and the refrigerator suffers. Snow on the back wall indicates a defrost problem.
May 15, 2008 | Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Dometic RM2652 Refrigerator Logo
331 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
