Question about Tally T2340/24 Matrix Printer
TOF moves I have set the position of the first line to be printed. On first test it works correctly. On second test it moved down by one line. On third test it moved back up by one line. On fourth test it moved down by one line. Etc. Etc.
    New Friend:
  • 114 Answers
Check your paper settings. the problem comming from incorrect paper settings.
Posted on Jan 30, 2009
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 15, 2014 | Swintec 7040 Typewriter
Cant get my printer to line properly for invoice printing.
Setting Top of Form, Forms Tear-Off ON
(Step A)
! If you turn the platen knob when the printer is turned
on, you will cause the Top of Form to mis-align. Always
turn the printer off before turning the platen knob!
1 Turn the printer ON.
2 Park the paper.
3 With paper out of the unit, (red alarm light should be on)
press SHIFT (1) and QUIET/TOF (5) to reset the current
Top of Form.
4 Press FF/LOAD (3) to load the paper.
5 Press SEL/MENU (6) to take the printer off line.
The SEL light goes out.
6 Wait until the paper moves up to the tear position, then
press and hold TEAR (4).
The paper moves to the current Top of Form.
Keep pressing and holding TEAR.
7 Press and hold SHIFT and release TEAR.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 27, 2011 | Matrix Okidata Microline 320 Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
Prints on two cards
You can modify the position in the menu.
The start position can be prgrammed in the personal settings.
Moving the paperwon't change anything because the printer will always check the top of feed
Sep 03, 2009 | Datamax I-4208 Thermal Label Printer
Image moves 2 " down when printing through adf in only legal size
Enter service mode > additional functions 2 8 additional functions >select feeder > funtion tab> set adf guides to legal settings > select TRY-LGL on the lcd display> select ok>
test if not corrected
then
select adjust> DOCST > use keypad to set adjustment value> select OK
select LA-Speed> use keypad to set adjustment value> select OK
Remember to write down the original values before changing them in case you need to set them back.
Jul 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Line down the right stide in the megenta area of the self test and blurrred print on the right side
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Oct 31, 2008 | HP PSC 2175 All-In-One InkJet Printer
Tally t2250problom
go in setup ,check paper ,inside size ,width,
select one that u want and save it & test
Dec 06, 2007 | Tally T2250 Matrix Printer
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Printer performs inverse action when using TOF
If I understand correctly, this TOF action involves moving the paper backwards until the top edge moves past the paper (paper out?) sensor. Perhaps this sensor, either an optical sensor, or mechanical switch is covered up by an extraneous piece of paper, or, if mechanical, stuck or broken. Also the sensor itself might be bad, and not sending the logic circuit a valid signal. This could be checked with a voltmeter or oscilloscope especially if you have an accurate idea of what voltages should be.
Apr 20, 2007 | Tally Line Matrix T6050 Printer
Tally T2340/24 Matrix Printer Logo
118 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
