Question about Sony VAIO PCG-K35 Notebook
Upgrade memory what do I need to do to upgrade the memory. what screw do I need to remove on my sony vaio pcg-k315b laptop
    Novelist:
  • 126 Answers
All u need to do is that go to this website and follow the steps....
Sony’s esupport site
http://esupport.sony.com/perl/model-documents.pl?mdl=PCGZ1RA
or if this doesnt work then try this website
http://www.memorystock.com/support.htm
OR
on the bottom of the laptopThere is a panel with 2 screws in it. normally this panel will have a picture of ram on it or will denote it somehow. after the two screws are removed the panel can be removed and you will see the 2 SODIMM slots one will be occupied and you can place your module in the second one.
good luck...
Posted on Jan 26, 2009
How to remove a hard drive from a sony vaio pcg-6n1l
Turn laptop over and remove screws from HDD compartment door.. Remove screws holding HDD in place and remove.
Nov 22, 2013 | Sony VAIO PCG-6N1L, PCG-6N2L, PCG-6N3L...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have a sony Vaio PCG-FRV25. I upgraded the
Have you run memtest on the new ram?
Here is a link. Hope this helps.
http://www.memtest86.com/
then click on the free download section
Nov 07, 2009 | Sony VAIO FRV25 Notebook
Upgrade on Memory Card
When you said memory cards i assume you mean the RAM. You can just take out the ram and put in new ones. Nothing else.
Nov 01, 2009 | Sony VAIO PCG-K27 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Upgrade memory - computer now won't turn on or boot
Follow this link to do it,
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2108&site=voe_en_GB_cons
Hope this helps
TC and Cheers!!!!!!!!!!!!!
May 29, 2009 | Sony VAIO PCG-K35 Notebook
Remove keyboard
You need to locate screws below you laptop, the keyboard was ajusted by some screws(2-4), Vaio do this in almost all models. Detach your screws and your kb will be removed.
thanks
vcrtech
Apr 20, 2009 | Sony VAIO PCG-GRT100F PC Notebook
Need to upgrade my vaio
hi there,
Sony PCG-GRS750 or PCG-GRS300 all go back to the sony ( PCG-8K1L )
Maximum CPU is Pentium 4 Processor 2.0GHz
Maximum memory is 512 DDR PC2700
Apr 09, 2008 | Computers & Internet
Hard disk crashed
I think it maybe mounted through to top of your laptop under the keyboard, for instructions on how to remove keyboard and sometimes the HDD is held in a carrier. click below http://www.vaio-link.com/tutorials/memory/memory.asp?l=en&category=0&serie=PCG-Z1&m=1165
Nov 01, 2006 | Sony VAIO PCG-Z1WAMP1 Notebook
Sony VAIO PCG-K35 Notebook Logo
81 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
