Question about LG Washing Machines
Service manuel for lg direct drive 7 3.5kg wd 14331ad
Damage ic regulater
3 Suggested Answers
  • 161 Answers
SOURCE: IE problem
This is a water inlet error. Shut the water off and remove the hoses. Look ito the valves where the hoses screw on with a flashlite. If the filter screens are obstructed pull them with needle nose pliers. Clean them and replace them into the valves. Re attach hoses and try machine. If it still shows the code you have a bad valve.
Posted on Jan 28, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My LG intellowasher 7,5kg WD-
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
Hi, I have a LG Tromm WD-14331AD. At the start of the wash cycle, water will dispense, but not a lot. When spinning, there is hardly any water in the drum and water just stops dispensing.
A front loader only uses a very small amt of water. That's the point of front loaders. Make sure u only use a very small amt of detergent also. And use white vinegar in place of fabric softener. If washer is slow to fill you can check the filters in the supply lines. Take the water lines off the back of the washer and check the filters in the washer
Jan 01, 2017 | LG Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Washer won't turn on
you have to check there power supply cable...and power on button..step down transformer on the pcb....7805 and 7812 power regulater ic
May 22, 2013 | LG WM2140CW Washer
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
IE problem
Jan 27, 2010 | LG WD-16115FD Front Load Washer
I drop my WD storage device and now I can now
You need to take it in for servicing and to find out if the drive in it is damaged. IF the drive itself is damaged, then a recovery service MIGHT be able to salvage your data. It is possible that a connector came loose in the unit and that would be an easy fix.
Nov 24, 2009 | Western Digital WD Passport 250GB Portable...
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Characters are scrambled
check connections of R.G.B.and 15 pins to end thenif ok then check positive Vcc at the ic on crt base if less than 12v then check regulater ic if faulty replace it display also can be corrected by adjusting ring magnets on yoke coil
Oct 14, 2008 | LG Studioworks 45 14" CRT Monitor
MT42PZ10 LG plasma
I have the ic in stock,, it is 69 dollars.
Aug 19, 2008 | Televison & Video
Washing Machines Logo
63 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
