Question about SanDisk 2GB microSD Memory Card
My 4gb scan disc sd card wont format
When i try to format my 4gb sd card it keeps saying format failed
    Brigadier General:
  • 5,158 Answers
Http://www.sandisk.com/Retail/Default.aspx?CatID=1668
I believe sandisk makes a special program to format their cards
Robert
Posted on Jan 26, 2009
My camera akodak easy share, DX6490 Has 2 sanDisk 128mb that Ibought with the camera in 2003 Works fine. The new sandisk cards 4gb say they need to be formatting. The camera keeps repeating it needs...
If you've tried to format the cards in the camera and it failed, it's probably because the cards are SDHC cards instead of SD. With a camera as old as yours, SDHC cards hadn't come out yet.
Aug 18, 2011 | Cameras
( canon power shot a 530 ) IF i try to use a card of 4gb or more, screen says card error. is there anything i can do to use a 4gb card or more?
Usually that just means you are limited to the smaller size cards or certain version of the 4gb cards. As an example I can use the normal SD card but get that exact error if I try to use a SDHC version.
4GB is the cross over size so you get both versions but 2gb should work fine (and they are dirt cheap too!)
Jan 24, 2011 | Cameras
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
Put in a 4gb SD card, camera says needs to format, I say ok, it say all pics will be lost, I say ok, and pick continue and then again it says needs to be formatted, and repeats this again and again
There are no 4GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 06, 2010 | Kodak EasyShare Z740 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
Problems with formatting memory card
I'm guessing you're trying to format a new 4GB SDHC card? If so, am sorry to say that your camera was designed before the SDHC format came out. Although it looks exactly the same as a standard SD card, the format the card uses is very different.
You'll need to instead purchase a standard SD card (those that are 2GB or less). Forunately these are very inexpensive these days, with 2GB cards going for around $6 with shipping.
But if you must use 4GB, Transcend makes a 4GB standard SD card, but I can't guarantee that it will work with your camera as anything above 2GB for standard SD may have compliance issues.
Nov 02, 2009 | Cameras
My computer nor samsung alias wont read my 4gb pny microsd chard
I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
MAx SD size that works in a Z650 Digital camera
You can use 1GB SD card or 2GB SD card., more than 2GB is not compatible on your Z650., Gudluck!
Nov 28, 2008 | Kodak EasyShare Z650 Digital Camera
Sd card formatting
Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
Oct 22, 2007 | HP Photosmart R707 Digital Camera
SanDisk 2GB microSD Memory Card Logo
539 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
